When expanding data storage capacity, deploying multiple servers can lead to complexity in management and dramatically increased costs. QNAP TX-800P expansion enclosure provides a flexible expansion alternative designed with easy setup in mind for scaling up Thunderbolt NAS storage space via high-speed Thunderbolt 2 (20Gbps) cables. The TX-800P provides an additional 8 hard drives providing up to 64 TB expanded capacity for the Thunderbolt NAS, making it ideal for data backup, 4K digital media collection and video surveillance storage with blazing-fast data transmission performance.
Product Description | QNAP TX-800P - hard drive array | Device Type | Hard drive array | Interface | Thunderbolt 2 | Installed Devices / Modules Qty | 0 (installed) / 8 (max) | Supported Drives | SATA-600 | Built-in Devices | Status LCD | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | No HDD | Power | AC 120/230 V - 50/60 Hz | Dimensions (WxDxH) | 29.82 cm x 23.54 cm x 18.52 cm | Weight | 7.3 kg |
General | |
Chassis | |
Installed Devices / Modules Qty | 0 |
Supported Devices / Modules Qty | 8 |
Storage | |
HDD Array External Interface | Thunderbolt 2 |
Storage Controller | |
Type | SATA |
Interface Type | SATA 6Gb/s |
Data Transfer Rate | 600 MBps |
Hard Drive | |
Type | No HDD |
Expansion / Connectivity | |
Expansion Bays | 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" shared |
Interfaces | 2 x Thunderbolt 2 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), built-in 2 cooling fans |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V - 50/60 Hz |
Power Provided | 250 Watt |
Dimensions & Weight | |
Width | 29.82 cm |
Depth | 23.54 cm |
Height | 18.52 cm |
Weight | 7.3 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
