If you're looking for the fastest way to keep your Xbox controller at prime power levels, then go for the perfect pairing with the Razer universal quick charging stand for Xbox
Quick Charge
Able to fully charge your controller in under 3 hours, the stand is also designed with overcharge protection to prevent overheating and short circuiting
Universal Compatibility
Whether you're on next-gen, last-gen, or staying oldschool, the Razer Universal Quick Charging Stand for Xbox works with all controllers old and new.*
*Excluding Xbox Elite Controller Series 2
Magnetic Contact System
Mount your controller easily and never worry about its charge being interrupted thanks to a magnetic design that secures the controller to the stand.
Matches your Xbox Controller
To perfectly suit your setup, this charging stand uses the same durable material and shares the same striking colors as official Xbox Series X|S controllers.
Power By USB
Simply hook up the charging stand to your Xbox, PC, or compatible wall plugs to get it working.
What’s Inside
Product Description | Razer charging stand | Product Type | Charging stand | Colour | Electric volt | Designed For | Microsoft Xbox One Wireless Controller, Wireless Controller | Manufacturer Warranty | 1 Year |
General | |
Designed For | Wireless game controller |
Enclosure Colour | Electric volt |
Power Device | |
Input Connectors | 24 pin USB-C |
Features | Magnetic fixation |
Compatibility Information | |
Manufacturer Warranty | |
Service & Support | 1 Year |
