Easy to use, the THETA SC2 for Business allows any beginners to capture high-quality 360-degree images.
Specially created for business activities, THETA SC2 for Business is the tool which will help you to immerse your collaborators and customers into your projects.
Aside from the unlimited possibility it gives to viewers and content creators; it encourages engagement and, through this, has over 3 times the conversion rate of traditional video content and a 30% higher repeated view rate. The RICOH THETA SC2 for Business snaps photos at approximately 14 megapixels with smooth, immersive 360°spherical video at 30 fps (frames per second) in 4K (3840 × 1920 pixels).
Product Description | Ricoh THETA SC2 - for Business - camcorder - internal flash memory | Product Type | Camcorder - 4K | Synchronised Camera Array | Spherical panorama | Media Type | Internal flash memory | Internal Storage | 14 GB flash | Wireless Interface | Wi-Fi, Bluetooth | Sensor Resolution | 2 x 12.0 MP | Max Video Resolution | 3840 x 1920 | Lens System | 2 x fisheye lens f/2.0 | Focus Adjustment | Focus free | Min Focus Distance | 10 cm | Image Stabiliser | Electronic | Supported Battery | Li-ion rechargeable battery (included) | Colour | Grey | Dimensions (WxDxH) | 4.52 cm x 2.29 cm x 13.06 cm | Weight | 104 g | Manufacturer Warranty | 3-year warranty |
General | |
Enclosure Colour | Grey |
Camcorder Type | |
Sensor Resolution | 2 x |
Camcorder Sensor Resolution | 12.0 MP |
Sensor Qty | 1 CMOS |
360° Camera | Yes |
Camcorder Media Type | Internal flash memory |
Optical Sensor Type | CMOS |
Optical Sensor Size | 1/2.3" |
Frame Rate (Max Resolution) | 30 fps |
ISO (Max) | 6400 |
Face Detection | Yes |
Print Standard | Exif Print support |
Face Detection | Face Recognition |
Digital Video Format | H.264 |
Image Recording Format | JPEG |
Audio Signal Format | AAC LC |
Interface | Wireless LAN, Bluetooth |
Connectivity Features | Remote control via mobile devices, remote live view, Wireless Image Transfer |
Exposure & White Balance | |
Light Sensitivity | ISO 64-6400 |
Exposure Modes | Programme, automatic, manual, shutter-priority, ISO priority |
White Balance | Automatic, presets |
White Balance Presets | Incandescent, cloudy, outdoor, shade, fluorescent light (warm white), Underwater, 2500K - 10000K, fluorescent light (daylight colour), fluorescent light (natural white), fluorescent light (white) |
Max Shutter Speed | 1/25000 sec |
Min Shutter Speed | 60 sec |
Exposure Compensation | ±2 EV range, in 1/3 EV steps |
Lens System | |
Type | 2 x fisheye lens f/2.0 - fisheye |
Lens Construction | 6 groups / 7 elements |
Additional Features | |
Self-Timer Delay | 10 sec, 2sec, 30 sec |
Additional Features | Interval shooting mode |
360° Camera | |
Panorama Type | Spherical |
Optical Sensor Qty | 2 |
Connections | |
Connector Type | USB 2.0 (5 pin Micro-USB Type B) |
Miscellaneous | |
Included Accessories | Soft case, lens cap, USB cable |
Battery | |
Battery Type | Lithium Ion - integrated |
Details | Li-ion rechargeable battery (included) |
Battery Life Details | Photo shooting - 260 shots , Video recording - 60 minutes |
Memory / Storage | |
Image Storage | 5376 x 2688 |
Video Capture | H.264 - 3840 x 1920 p - 29.97 fps , H.264 - 1920 x 960 p - 29.97 fps |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight | |
Width | 4.52 cm |
Depth | 2.29 cm |
Height | 13.06 cm |
Weight | 104 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 0 - 90% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
