Ring Alarm 5 Piece Kit (2nd Generation) is a great way to get started in whole-home protection for your house or flat. This kit includes a Base Station, Keypad, one Contact Sensor, one Motion Detector, and a Range Extender.
Product Description | Ring Alarm Security Kit - 2nd Generation - 5-piece set - home security system - Wi-Fi, Z-Wave - white | Product Type | Home security system | Environment | Indoor | Power Source | Battery, power adapter | Package Content | Door and window sensor, motion sensor, keypad, base station, extender | Connectivity | Wireless, wired - Wi-Fi, Z-Wave - Ethernet | Siren Sound Level | 104 dB | Input Type | Keypad | Colour | White | Manufacturer Warranty | 1-year warranty |
General | |
Connectivity Technology | Wireless, wired - Ethernet, Z-Wave, Wi-Fi |
Max Range Open Space | 76 m |
Features | Panic button, Away Mode, arm/disarm function, 24 hours backup battery, status notification, Home Mode |
Control Unit | |
Battery | |
Form Factor | AA / CR2032 |
Battery Included | Yes |
Miscellaneous | |
Included Accessories | 2 power adapters |
Colour | White |
Voltage Required | AC 100-240 V |
Dimensions & Weight | |
Dimensions & Weight Details | Base station: 17 cm x 17 cm x 3.7 cm , Keypad: 10.5 cm x 1.9 cm x 11.2 cm , Door and window sensor: 4 cm x 1.4 cm x 5.3 cm , Motion sensor: 6.6 cm x 3.6 cm x 6.6 cm , Extender: 4.7 cm x 3.5 cm x 8.1 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
