Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
Ring Alarm 5 Piece Kit (2nd Gen)
free standard delivery
EASY TOOL-FREE, DIY INSTALLATION
£219.99
Delivery:
Standard: 1-3 working days
Key features
  • Get notifications when doors or windows are opened or when motion is detected at your home when the system is armed
  • Monitor your home from any iOS or Android device
  • Control your entire home security from one simple app
  • Easy setup with no tools or professional installation required
  • 24-hour backup battery power and 104-decibel siren
  • Type: Home security system
  • Compatible With: Alexa
Product codes
chevron icon
chevron icon
Ring Alarm 5 Piece Kit (2nd Generation) is a great way to get started in whole-home protection for your house or flat. This kit includes a Base Station, Keypad, one Contact Sensor, one Motion Detector, and a Range Extender.
  • New-look Keypad, slimmer Contact Sensor and more discreet Motion Detector
  • Control it all in the Ring app for whole-home security at your fingertips
  • Receive real-time notifications when your system is triggered
  • Choose between three security modes: Home, Away, and Disarmed
  • Alert others in an emergency with new panic buttons
  • Easily expand your whole-home protection with additional Contact Sensors,
  • Motion Detectors and Outdoor Siren
  • Add Assisted Monitoring and Cellular Backup with a Ring Protect Plan
  • Everything you need for tool-free, DIY installation comes in the box
  • Works with compatible Alexa-enabled devices for voice control
  • Compatible with 1st and 2nd generation devices and accessories
chevron icon
Product Description Ring Alarm Security Kit - 2nd Generation - 5-piece set - home security system - Wi-Fi, Z-Wave - white
Product Type Home security system
Environment Indoor
Power Source Battery, power adapter
Package Content Door and window sensor, motion sensor, keypad, base station, extender
Connectivity Wireless, wired - Wi-Fi, Z-Wave - Ethernet
Siren Sound Level 104 dB
Input Type Keypad
Colour White
Manufacturer Warranty 1-year warranty
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£219.99
