Keep your compatible Video Doorbell powered 24/7 from a standard electrical socket, with the easy to install Plug-In Adapter for Doorbells. With Plug-In Adapter for Doorbells, your Video Doorbell will be ready to protect your home around the clock, without the need for battery changes or professional installation.
Ref: HDN6 048600 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£13.96
