Get an additional easy-to-use rechargeable Quick Release Battery, and make sure your Ring devices are always ready to protect your home, without the need for hardwiring.
Nonstop Battery Power: When the battery pack in your Ring device runs low, replace it with a spare Quick Release Battery for nonstop power. Recharging is easy, simply press the tab to release from your device, then connect to a power supply with a micro-USB cable to begin charging. Swaps in and out of your device with a quick-release tab Charges using a micro-USB cable Can last for months between charges, depending on usage and weather
Product Description | Ring Quick-Release Battery Pack battery - Li-Ion |
General | |
Product Type | Battery |
Designed For | Camera, video doorbell |
Width | 4.5 cm |
Depth | 2.25 cm |
Height | 7 cm |
Enclosure Colour | Grey |
Power Device | |
Input Connectors | 5 pin Micro-USB Type B |
Battery | |
Technology | Lithium Ion |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Limited warranty - money back guarantee - 30 days |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
