Spotlight Cam Wired
HD camera with two-way talk and spotlights, plugged-in for non-stop power and security.
Home Security in Your Hands
Protect and monitor your home with Spotlight Cam Wired, a plugged-in HD security camera that lets you see, hear and speak to anyone on your property from your phone, tablet and PC.
• Brilliant 1080HD video
• Wide-angle camera lens
• Built-in microphone and speakers
Never Miss a Thing
Create and customize your own motion zones, so you can focus on the most important areas of your yard. When motion is detected, you’ll get an instant alert to let you know someone’s at your home.
• Advanced motion detection
• Custom motion zones and scheduling
• Instant motion-activated alerts
Stop Crime Before It Happens
With built-in spotlights and night vision, you’ll get crisp video 24/7, with or without the lights on. And if you catch a suspicious stranger at your home, use the 110-decibel alarm to scare them away.
• Spotlights are motion-activated or controlled with the app
• Infrared night vision sensors
• 110-decibel siren alarm
Non-Stop Power and Security
Spotlight Cam Wired plugs into standard power outlets to give you non-stop power, so you’ll never need to charge a battery. It also comes with everything you need to get your Cam setup in just minutes.
• Plug-and-play installation
• Live View on-demand video and audio
• iOS, Android, Mac and Windows 10 compatible
Ring Protect Plans
Real-time Ring alerts, Real-time motion alerts, Custom motion detection, Two-way talk, Live View and Theft Protection are included as standard with all Ring products. All Ring products come with a 2 year warranty.
If you want to store, review, share and download videos from your events you will need to purchase a Ring Protect Plan, available from £2.50 per month. These are available from https://en-uk.ring.com/pages/protect-plans.
Product Description | Ring Spotlight Cam Wired - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor - weatherproof | Audio | Yes: built-in speaker, built-in microphone | Dimensions (WxDxH) | 6.91 cm x 7.59 cm x 12.6 cm | Colour | Black | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Video Modes | 1080p | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Features | Motion sensor, built-in siren | Manufacturer Warranty | 2 year warranty | Environmental Parameters (operating) | -28 °C - 48 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, built-in microphone |
Width | 6.91 cm |
Depth | 7.59 cm |
Height | 12.6 cm |
Camera | |
Type | Colour - Day&Night - fixed - outdoor - weatherproof |
Infrared LEDs | Yes |
Lens Construction | |
Horizontal Field of View (degree) | 140 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Miscellaneous | |
Colour | Black |
Power | |
Power Device | Power adapter |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts - 2 year |
Environmental Parameters | |
Min Operating Temperature | -28 °C |
Max Operating Temperature | 48 °C |
