ITEM | QTY | PRICE |
StarTech.com 0.3 m Round SATA Cable -...
3 | £17.04 |
Go Beyond.
Product Description | Samsung Odyssey G7 S28BG700EP - G70B Series - LED monitor - 4K - 28" - HDR | Device Type | LED-backlit LCD monitor - 28" - Smart monitor | Energy Class | Class F | Energy Consumption per Year | 40 kWh | Adaptive-Sync Technology | AMD FreeSync Premium Pro, NVIDIA G-SYNC Compatible | Features | Wi-Fi, USB 3.0 hub, Gigabit Ethernet network adapter, Bluetooth 5.2 adapter | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 144 Hz | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 | HDR Capable | HDR10+ / DisplayHDR 400 | Response Time | 1 ms (grey-to-grey) | Gaming | Yes | Colour Support | 1 billion colours | Colour Gamut | 90% DCI | Input Connectors | 2xHDMI, DisplayPort | Built-in Ethernet | Yes | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 100-240 V | Colour | Black | Dimensions (WxDxH) - with stand | 63.79 cm x 24.48 cm x 57.7 cm | Weight | 7 kg | Compliant Standards | CEC |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix - Smart monitor |
Energy Class (HDR) | Class G |
Diagonal Size | 28" |
Operating System | Tizen |
Built-in Devices | Wi-Fi, USB 3.0 hub, Gigabit Ethernet network adapter, Bluetooth 5.2 adapter |
Panel Type | IPS |
HDR Format | HDR10+ |
HDR Certification | DisplayHDR 400 |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Game mode, ConnectShare, Eco Light Sensor, Flicker Free technology, Image Size, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Movie Mode, DLNA, Graphics Mode, Dynamic Contrast Mode, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tap View, Sound Mirroring, SmartThings App Support, CoreSync lighting design, Adaptive Sound, Game Bar 2.0, far-field voice interaction, Virtual AIM Point, Bixby Voice Assistant, Mobile to Screen Mirroring, Gaming Hub, SmartThings, Workspace, Samsung TV Plus, Entertain Mode |
Colour | Black |
Dimensions (WxDxH) | 63.79 cm x 24.48 cm x 57.7 cm - with stand |
Weight | 7 kg |
Audio | |
Type | Speakers |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort 1.4 , Headphone jack (mini-jack) , 2 x USB 3.0 , LAN (RJ-45) |
Mechanical | |
Tilt Angle | -9/+13 |
Swivel Angle | 30 |
Rotation Angle | -92/+92 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Remote control |
Cables Included | 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V |
Power Consumption SDR (On mode) | 27 kWh/1000h |
Power Consumption HDR (On mode) | 55 kWh/1000h |
Power Consumption (Typical) | 27.2 Watt |
Power Consumption (Max) | 80 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Intel Wireless Display, Microsoft 365, SmartThings, Samsung TV Plus, Google Duo, Bixby Voice Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 63.79 cm - depth: 24.48 cm - height: 57.7 cm - weight: 7 kg , Without stand - width: 63.79 cm - depth: 10.86 cm - height: 38.05 cm - weight: 5.1 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 71.6 cm |
Shipping Depth | 16.9 cm |
Shipping Height | 48.9 cm |
Shipping Weight | 9.6 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
