Bridging the gap between enterprise storage and cache memory with ultra-low latency. The 983 ZET bridges the gap between storage memory and cache memory by offering a new level of performance with ultra-low latency, high QoS, breakthrough speeds and ultra-high reliability. Ideal for high-performance computing applications such as hybrid caching servers, database servers, AI and IoT, the 983 ZET is a perfect companion to Samsung's DCT SSDs as a powerful cache memory solution to completely enhance server performance.
Product Description | Samsung 983 ZET MZ-PZA480BW - SSD - 480 GB - PCIe 3.0 x4 (NVMe) | Type | Solid state drive - internal (desktop) | Capacity | 480 GB | Hardware Encryption | Yes | Form Factor | PCIe card (HHHL) | Interface | PCIe 3.0 x4 (NVMe) | Buffer Size | 1.5 GB | Features | TRIM support, Auto Garbage Collection Algorithm, V-NAND Technology, Low Power DDR4 SDRAM Cache, Samsung Phoenix Controller, S.M.A.R.T. | Dimensions (WxDxH) | 69.9 mm x 167.7 mm x 18.8 mm | Weight | 330 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal (desktop) |
Capacity | 480 GB |
Width | 69.9 mm |
Depth | 167.7 mm |
Height | 18.8 mm |
Weight | 330 g |
Performance | |
SSD Endurance | 7.44 PB |
Internal Data Rate | 3400 MBps (read) / 3000 MBps (write) |
Maximum 4KB Random Write | 60000 IOPS |
Maximum 4KB Random Read | 750000 IOPS |
Reliability | |
MTBF | 2,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x PCI Express 3.0 x4 (NVMe) - PCI Express |
Compatible Bay | PCIe card (HHHL) |
Power | |
Power Consumption | 9 Watt (typical) , 5.5 Watt (idle) |
Software & System Requirements | |
Software Included | Samsung SSD Magician DC |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 55 °C |
Shock Tolerance (operating) | 1500 g @ 0.5 ms half-sine |
