Marketing description is not available.
Product Description | Samsung UE49NU7500U 7 Series - 49" LED-backlit LCD TV - 4K | Product Type | Curved LED-backlit LCD TV - Smart TV | Diagonal Class | 49" | Colour | Charcoal black | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | HDR Format | HDR10+, HLG10 | Frame Rate & Enhancement Technology | 1800 Picture Quality Index | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | LED backlight UHD dimming | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-S2, DVB-T2 | Internet Streaming Services | HbbTV, Steam Link | Picture Enhancements | Digital Clean View, Mega Contrast, Auto Depth Enhancer, Dynamic Crystal Color | Speaker System | 2 speakers | Platform | SmartThings | USB | 2 ports | Included Accessories | Samsung TM1850A remote control, batteries | Voltage | AC 230V (50/60 Hz) | Energy Class | Class A | Power Consumption Operational | 135 Watt | Power Consumption (On mode) | 90 W | Energy Consumption per Year | 125 kWh | Dimensions (WxDxH) - without stand | 110.15 cm x 9.56 cm x 63.85 cm | Weight | 13.3 kg |
General | |
Curved Screen | Yes (4200R) |
Series | 7 Series |
HDR Capable | Yes |
Video Processor | Quad-Core |
TV Tuner Presence | Yes |
Sensors | Eco Sensor |
Modes | Film Mode, Natural Mode, Auto Game Mode |
Design | Very Narrow Bezel Design (VNB), Slim Design, New Edge Design, Flat Bezel Design |
Dimensions | Without stand |
Width | 110.15 cm |
Depth | 9.56 cm |
Height | 63.85 cm |
Weight | 13.3 kg |
Enclosure Colour | Charcoal black |
Display | |
Display Menu Language | Multilingual |
Features | Time-shift, HDMI quick switch, Auto Motion Plus, E-Manual, Voice Assistant, MBR Support, clean cable solution |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Teletext | Yes |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Remote control |
Remote Control Model | Samsung TM1850A |
Features | Samsung Smart Control included |
Audio System | |
Digital Audio Format | Dolby Digital Plus output |
Output Power / Total | 20 Watt |
Features | Voice Control, Audio Return Channel (ARC), Dolby Digital Plus, Voice Interaction |
Speakers | 2 x speaker - 10 Watt |
Network & Internet Multimedia | |
Functionality | Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Connect & Share | Wi-Fi Direct, Screen Mirroring, USB Human Interface Device (HID), ConnectShare, Bluetooth Human Interface Device (HID) |
Supported Consumer Electronics Control (CEC) | Anynet Plus, Multiroom Link |
DLNA | Yes |
Connections | |
Connector Type | 3 x HDMI , 2 x USB , Composite video / component video input , LAN , Digital audio output (optical) |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Communications Technology | Bluetooth Low Energy (LE) |
Miscellaneous | |
Included Accessories | Batteries |
Compliant Standards | IPv6 Ready |
Power | |
Power Device | Power supply |
Input Voltage | AC 230V (50/60 Hz) |
Auto On/Off | Yes |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 110.15 cm x 9.56 cm x 63.85 cm x 13.3 kg , Panel with stand - 110.15 cm x 33.62 cm x 72.45 cm x 16 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 127.4 cm |
Depth (Shipping) | 20.2 cm |
Height (Shipping) | 77.8 cm |
Weight (Shipping) | 21.6 kg |
