Marketing description is not available.
Product Description | Samsung 860 QVO MZ-76Q4T0BW - SSD - 4 TB - SATA 6Gb/s | Type | Solid state drive - internal | Capacity | 4 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | NAND Flash Memory Type | Multi-level cell (MLC) | Form Factor | 2.5" | Interface | SATA 6Gb/s | Buffer Size | 4 GB | Features | TRIM support, Garbage Collection technology, sleep mode, V-NAND Technology, Samsung MJX Controller, Low Power DDR4 SDRAM Cache, S.M.A.R.T., 256-bit AES | Dimensions (WxDxH) | 69.85 mm x 100 mm x 6.8 mm | Weight | 62 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 4 TB |
Width | 69.85 mm |
Depth | 100 mm |
Height | 6.8 mm |
Weight | 62 g |
Performance | |
SSD Endurance | 1440 TB |
Internal Data Rate | 550 MBps (read) / 520 MBps (write) |
4KB Random Read | 7500 IOPS |
4KB Random Write | 42000 IOPS |
Maximum 4KB Random Write | 89000 IOPS |
Maximum 4KB Random Read | 97000 IOPS |
Reliability | |
MTBF | 1,500,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 3.1 Watt (average) , 5.4 Watt (maximum) , 0.03 Watt (idle) |
Miscellaneous | |
Compliant Standards | IEEE 1667 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Shock Tolerance (operating) | 1500 g @ 0.5 ms half-sine |
