Samsung 500GB mSATA 6GBp/s 850 EVO SSD
1 on order, delivery delayed
Key features
  • Optimize daily computing with TurboWrite technology for unrivaled read/write speeds
  • Get into the fast lane with the improved rapid mode
  • Guaranteed endurance and reliability bolstered by 3D V-NAND technology
  • Compute longer with improved energy efficiency backed by 3D V-NAND
  • Secure valuable data through advanced - AES 256 encryption
  • Protect against overheating with a highly responsive - Dynamic Thermal Guard
Product codes
Achieve the ultimate read/write performance to maximize your everyday computing experience with Samsung's TurboWrite technology. You not only obtain more than a 10% better user experience but up to 1.9x faster random write speeds. The 850 EVO delivers the top of its class performance in sequential read and write speeds. Plus, you also gain optimized random performance in all QD for client PC usage scenario.
Samsung's Magician software which provides rapid mode for 2x faster processing data speeds on a system level by utilizing unused PC memory (DRAM) as cache storage. The Magician increased the maximum memory usage in rapid mode. You also get a 2x performance boost in all random queue depth.
The 850 EVO delivers significantly longer battery life on your notebook with a controller optimized for 3D V-NAND now enabling device sleep at a highly efficiency. The 850 EVO is now 25% more power efficient during write operations thanks to 3D V-NAND only consuming half the energy than that of planar 2D NAND.
Product Description Samsung 850 EVO MZ-M5E500BW - solid state drive - 500 GB - SATA 6Gb/s
Type Solid state drive - internal - TRIM support, DevSleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, Worldwide Name (WWN), Samsung MEX Controller
Capacity 500 GB
Hardware Encryption Yes
Form Factor mSATA
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 512 MB
Features TRIM support, DevSleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, Worldwide Name (WWN), Samsung MEX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
Dimensions (WxDxH) 30 mm x 50.8 mm x 3.81 mm
Weight 9.07 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
