ITEM | QTY | PRICE |
Toshiba Enterprise HDD 10TB 3.5’’ SAT...
4 | £1,054.68 |
Whether you're carrying games, movies, or sensitive work files, the Portable SSD T7 Touch gives you speed and security in a palm-sized package. Experience the next level of external storage.
Product Description | Samsung T7 Touch MU-PC500K - SSD - 500 GB - USB 3.2 Gen 2 | Type | Solid state drive - external (portable) | Capacity | 500 GB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | Interface | USB 3.2 Gen 2 - USB-C | Data Transfer Rate | 10.0 Gbps (USB 3.2 Gen2) | Features | Fingerprint recognition, shock resistant, password authentication, USB Attached SCSI Protocol (UASP) compliant, V-NAND Technology, 256-bit AES | Power Source | USB bus | Enclosure Colour | Black | Dimensions (WxDxH) | 8.5 cm x 0.8 cm x 5.7 cm | Weight | 51 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - external (portable) |
Capacity | 500 GB |
Interface | USB 3.2 Gen 2 |
Width | 8.5 cm |
Depth | 0.8 cm |
Height | 5.7 cm |
Weight | 51 g |
Performance | |
Interface Transfer Rate | 10.0 Gbps (USB 3.2 Gen2) |
Max Data Transfer Rate | 1050 MB/s |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.2 Gen 2 - 24 pin USB-C |
Power | |
Software & System Requirements | |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.10.x or later, Android 5.1 (Lollipop) or later |
Miscellaneous | |
Compliant Standards | UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KC, RoHS2, EAC, UASP (USB Attached SCSI Protocol) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
