All your must-see entertainment in striking 4K picture quality
Shows your content's true colours
PurColour
In this new golden age of TV, why settle for anything less than crystal clear colour TV? Samsung's PurColour improves the quality of any image, uncovers hidden details and helps show your content's true colours.
Powerful picture processing, stunning 4K clarity
Crystal Processor 4K
Simply relax and enjoy all the content you love, with a 4K upscaling TV that adapts to give you the best 4K Ultra HD picture. But it doesn’t stop there. The sound adjusts to perfectly suit what you’re watching. A TV drama or the tennis, you’ll really feel part of the action.
Experience the beauty of 4K
4K UHD Resolution
See all the details you’ve been missing on a crisp, clear Ultra HD picture — 4 times the resolution of Full HD.
See the stunning detail in every scene
HDR powered by HDR10+
Watch movies in striking picture detail — just as the directors intended. Samsung HDR TV technology uncovers all the finest details, even in the darkest and brightest scenes. Finally, discover what’s lurking in the shadows of a horror movie or witness the true beauty of a sun-lit scene.
Sound perfected for whatever you’re watching
Adaptive Sound
Get the perfect audio experience for whatever you’re watching with Adaptive Sound. From the latest boxset to the beautiful game, your Samsung TV adjusts the sound in every scene to what’s on screen, so you’ll hear every last detail.
Less bezel, more picture
3-sides Boundless Screen
Experience minimalistic style with a near bezel-less TV design that only leaves you to enjoy the beautiful picture.
Product Description | Samsung UE75AU7100K 7 Series - 75" LED-backlit LCD TV - 4K | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 75" | Colour | Titan grey | Platform | Tizen OS | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | HDR Format | HDR10+ | HDR Technology | Hybrid Log-Gamma (HLG), HDR 10+ | Frame Rate & Enhancement Technology | 2000 Picture Quality Index, Motion Xcelerator | Video Interface | HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | LED backlight UHD dimming | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-T2 | Internet Streaming Services | Netflix, Prime Video, Disney+, Samsung TV PLUS, HbbTV 2.0.2 | Picture Enhancements | Digital Clean View, Mega Contrast, contrast enhancer, PurColor | Speaker System | 2 channel | Intelligent Assistant | Google Assistant, Alexa (not available for some languages and countries) | USB | Yes | Included Accessories | Samsung TM2140A remote control | Voltage | AC 220-240 V (50/60 Hz) | Energy Class | Class G | Power Consumption Operational | 155 Watt | Power Consumption (On mode) | 155 W | Power Consumption Stand by | 0.5 Watt | Dimensions (WxDxH) - without stand | 167.32 cm x 5.99 cm x 95.82 cm | Weight | 30.4 kg |
General | |
Energy Class (HDR) | Class G |
Power Consumption (Max) | 250 Watt |
Power Consumption SDR (On mode) | 155 kWh/1000h |
Power Consumption HDR (On mode) | 220 kWh/1000h |
Series | 7 Series |
Model Year | 2021 |
HDR Capable | Yes |
Video Processor | Crystal 4K |
TV Tuner Presence | Yes |
Sensors | Eco Sensor |
Modes | Film Mode, Natural Mode, Auto Low Latency Mode (ALLM), Filmmaker Mode |
Design | 3 Bezel-less Design, New Bezel-less Design, Slim look, 3-side Boundless Design |
Dimensions | Without stand |
Width | 167.32 cm |
Depth | 5.99 cm |
Height | 95.82 cm |
Weight | 30.4 kg |
Enclosure Colour | Titan grey |
Display | |
Display Menu Language | Multilingual |
Features | HDMI quick switch, E-Manual, MBR Support, clean cable solution, Mega Contrast, Brightness Detection |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Stand Colour | Titan grey |
Stand Features | Slim Feet |
Flat Panel Mount Interface | Yes |
VESA Compatibility | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Teletext | Yes |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 1 |
Remote Control | |
Type | Remote control |
Remote Control Model | Samsung TM2140A |
Battery Included | Yes |
Audio System | |
Digital Audio Format | Dolby Digital Plus output |
Output Power / Total | 20 Watt |
Features | Audio Return Channel (ARC), Enhanced Audio Return Channel (eARC), Audio Pre-selection Descriptor, Adaptive Sound, Q-Symphony Lite |
Network & Internet Multimedia | |
Functionality | Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Wi-Fi Protocol | 802.11ac |
Bluetooth Version | Bluetooth 4.2 |
Connect & Share | Wi-Fi Direct, Screen Mirroring, USB Human Interface Device (HID), ConnectShare, Bluetooth Human Interface Device (HID), Sound Mirroring, Tap View |
Supported Consumer Electronics Control (CEC) | Anynet Plus |
DLNA | Yes |
Connections | |
Connector Type | 3 x HDMI , USB , LAN , Digital audio output (optical) |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Compliant Standards | IPv6 |
Power | |
Power Device | Power supply |
Input Voltage | AC 220-240 V (50/60 Hz) |
Auto On/Off | Yes |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 167.32 cm x 5.99 cm x 95.82 cm x 30.4 kg , Panel with stand - 167.32 cm x 34.11 cm x 104.79 cm x 30.8 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 184 cm |
Depth (Shipping) | 19.8 cm |
Height (Shipping) | 111.8 cm |
Weight (Shipping) | 41.9 kg |
