ITEM | QTY | PRICE |
OtterBox Symmetry Samsung Galaxy S22...
4 | £67.00 |
Samsung's 983 DCT is a high-performance solution for servers that need enhanced data reliability to safeguard critical data, from content delivery networks (CDNs) to big data, artificial intelligence (AI) and Internet of Things (IoT) applications. Available in two form factors, U.2 and M.2., the 983 DCT's NVMe interface empowers blazing-fast speed, high responsiveness and a high Quality of Service (QoS).
Product Description | Samsung 983 DCT MZ-1LB960NE - SSD - 960 GB - PCIe 3.0 x4 (NVMe) | Type | Solid state drive - internal | Capacity | 960 GB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | NAND Flash Memory Type | 3D triple-level cell (TLC) | Form Factor | M.2 22110 | Interface | PCIe 3.0 x4 (NVMe) | Buffer Size | 1.5 GB | Features | TRIM support, Auto Garbage Collection Algorithm, Enterprise Power-Loss Protection, Advanced ECC Engine, Samsung Phoenix Controller, S.M.A.R.T. | Dimensions (WxDxH) | 22 mm x 110.02 mm x 3.8 mm | Weight | 20 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 960 GB |
Width | 22 mm |
Depth | 110.02 mm |
Height | 3.8 mm |
Weight | 20 g |
Performance | |
SSD Endurance | 1366 TB |
Internal Data Rate | 3000 MBps (read) / 1100 MBps (write) |
Maximum 4KB Random Write | 38000 IOPS |
Maximum 4KB Random Read | 400000 IOPS |
Reliability | |
MTBF | 2,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x PCI Express 3.0 x4 (NVMe) - M.2 Card |
Compatible Bay | M.2 22110 |
Power | |
Power Consumption | 7.5 Watt (read) , 7.2 Watt (write) , 2.6 Watt (idle max) |
Software & System Requirements | |
Software Included | Samsung SSD Magician DC |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Shock Tolerance (operating) | 1500 g @ 0.5 ms half-sine |
