Samsung TV Promotion: Save up to £400 across the range.
Samsung F27T450FQU 27" 1920x1080 5ms HDMI DP LED Monitor
£159.99
19 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • The IPS panel preserves color vividness and clarity across every inch of the screen
  • The 3-sided borderless design provides seamless view in a multi-monitor setup
  • A variety of inputs allow to plug multiple devices straight into your monitor
  • Diagonal Size: 27in, 26-30 inches
  • Max Resolution: 1920 x 1080, Widescreen
  • Response Time: 5ms, 4-8ms
  • Speakers: None, No Speakers
  • Interfaces: HDMI, DisplayPort
Product codes
chevron icon
chevron icon
All-round colour clarity
See every inch clearly from any angle. The IPS panel preserves colour vividness and detail across the whole screen. Now, whole teams can work comfortably on the productivity-boosting wide display and view accurate tones and shades from 178Ëš all around, with no colour washing.
More screen to focus on
The borderless design maximises concentration. Take in everything with just one glance on a display that looks almost gapless when used in a dual-monitor setup. With no distractions in your way, get through larger sections of your to-do list during screen time.
More ways to connect
A variety of inputs bring a convenient computing experience. With 2x HDMI 1.4 ports and a display port, enjoy the versatility of being able to plug multiple devices straight into your monitor.
Tailored to your use
Superior design for the ultimate in everyday versatility. The height-adjustable monitor swivels, tilts and pivots for you to see your work any way you want. The sleek and clean design adds a touch of style to your office interior and is VESA-compatible for easy installation.
Fresh eyes achieve more
Protected eyes stay focused through the whole shift. Advanced eye comfort technology reduces eye strain for heightened concentration and greater productivity. Flicker Free technology continuously removes tiring and irritating screen flicker, while Eye Saver Mode minimises blue light emissions.
Energy-saving display
Eco Saving Plus achieves power-consumption reductions of up to 10% while still maintaining picture quality. It adjusts the brightness of the screen's black sections while simultaneously adjusting the RGB gain values, so the screen looks just as bright as you remember.
chevron icon
Product Description Samsung F27T450FQR - FT45 Series - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class D
Power Consumption (On mode) 17 W
Adaptive-Sync Technology AMD FreeSync
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Colour Gamut 72% (CIE 1931)
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Voltage AC 120/230 V
Colour Black
Dimensions (WxDxH) - with stand 61.21 cm x 22.4 cm x 39.16 cm
Weight 4.6 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£159.99
