The Galaxy A20e features a 5.8" Infinity V display, providing picture perfect quality, designed to keep up with your everyday demands.
Equipped with a powerful 3,000mAh battery, the A20e allows you to watch your favorite films, play games or multi-task, safe in the knowledge that your battery has true staying power, while its 15W fast-charging technology means that just a short charge is enough to get you going again.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Samsung Galaxy A20e - white - 4G smartphone - 32 GB - GSM | Product Type | 4G smartphone | Manufacturer Model Number | SM-A202F/DS | Display | LCD display - 1560 x 720 pixels - 5.8" - 294 ppi - PLS TFT | Features | FM radio | Processor | Exynos 7884B / 1.6 GHz (8-core) | Memory | RAM 3 GB / 32 GB | Supported Memory Card | microSDXC slot - up to 512 GB | Operating System | Android 9.0 Pie with One UI | Main Camera | 13 Megapixel - f/1.9 - focus: automatic | Second Camera | 5 Megapixel - ultra wide-angle lens - f/2.2 | Front Camera | 8 Megapixel f/2.0 | Service Provider | Not specified | SIM Card | Dual-SIM - nano SIM | Wireless Interface | Wi-Fi, NFC, Bluetooth | Security Devices | Fingerprint reader | Messaging Services | SMS, MMS | Connectors | 3.5 mm headset jack, USB-C | Talk Time | Up to 1140 minutes | Colour | White | Dimensions (WxDxH) | 69.7 mm x 8.4 mm x 147.4 mm | Weight | 141 g | Specific Absorption Rate (SAR) | 0.498 W/kg (head) , 1.303 W/kg (body) | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Integrated Components | FM radio |
Width | 69.7 mm |
Depth | 8.4 mm |
Height | 147.4 mm |
Weight | 141 g |
Body Colour | White |
SAR Value | 1.303 W/kg (body), 0.498 W/kg (head) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Operating System | Android 9.0 Pie |
User Interface | One UI |
Intelligent Assistant | Bixby |
Navigation | GPS, GLONASS, BeiDou, Galileo |
SIM Card Type | Nano SIM |
SIM Card Qty | Dual-SIM |
Input Device | Multi-touch |
Messaging & Internet | |
Supported Email Protocols | POP3, IMAP4, EAS |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE |
2G Band | 850 GSM, 900 GSM, 1800 GSM, 1900 GSM |
3G UMTS Band | Band 1, Band 2, Band 5, Band 8 |
3G UMTS Frequency | 2100, 1900, 850, 900 |
4G LTE Band | Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 38, Band 40 |
4G LTE Frequency | FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, TDD 2600, TDD 2300 |
Wireless Interface | IEEE 802.11b/g/n, NFC, Bluetooth 5.0 LE |
Phone Features | |
Phone Functions | Speakerphone, call timer, conference call, flight mode, vibrating alert |
Sensors | Accelerometer, proximity sensor, gyro sensor, hall sensor, geomagnetic sensor |
Media Player | |
Supported Digital Audio Standards | WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA |
Supported Digital Video Standards | MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4 |
Processor | |
Type | Exynos |
Processor Number | 7884B |
Clock Speed | 1.6 GHz |
Processor Core Qty | 8-core |
Memory | |
RAM | 3 GB |
Internal Memory Capacity | 32 GB |
User Memory | 21.5 GB |
Supported Flash Memory Cards | microSDHC, microSDXC - up to 512 GB |
Front Camera | |
Sensor Resolution | 8 Megapixel |
Lens Aperture | F/2.0 |
Light Source | Display flash |
Features | Stamps, AR sticker |
Main Camera | |
Sensor Resolution | 13 Megapixel |
Lens Aperture | F/1.9 |
Focus Adjustment | Automatic |
Digital Zoom | 4x |
Light Source | LED flash |
Video Resolutions | 1920 x 1080 (1080p) at 60 fps |
Second Camera | |
Sensor Resolution | 5 Megapixel |
Lens Type | Ultra wide-angle lens |
Lens Aperture | F/2.2 |
Field of View (FoV) | 123 degree(s) |
Display | |
Type | LCD display |
Technology | PLS TFT |
Diagonal Size | 5.8" |
Display Resolution | 1560 x 720 pixels |
Display Format | HD+ |
Pixel Density | 294 ppi |
Colour Depth | 16.7 million colours |
Features | Edge-to-Edge screen, Infinity V Display |
Connections | |
Connector Type | Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C |
Battery | |
Capacity | 3000 mAh |
Talk Time | 1140 minutes |
Run Time Details | Talk (WCDMA): up to 1140 min , Active online usage (3G): up to 13 hrs , Active online usage (4G): up to 15 hrs , Active online usage (Wi-Fi): up to 15 hrs , Playback (video): up to 14 hrs , Playback (audio): up to 61 hrs |
Miscellaneous | |
Included Accessories | Power adapter |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
