Impossibly thin design
High-polish metal and glass meld seamlessly — all in an impressively slim design.
Cinematic Infinity-O Display
With a tiny, front-facing camera lens, the display is a Dynamic AMOLED that's brilliant in all conditions.
Power to get you through your most demanding days
Our cutting-edge battery ensures your Galaxy Note10+ keeps up with your day.
The multi-camera system takes photography to a whole new level
Galaxy Note10 and Note10+ have all the camera essentials, from the dual aperture lens to the Ultra Wide Camera, Live focus and even Scene Optimiser.
Control your device through clicks and gestures
Air actions let you zoom in or out with the camera, change the volume, or flip through photos and more with a simple wave or click.
The screen you can write on when you need it
Take notes and draw on the screen whenever inspiration strikes without opening an app.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Samsung Galaxy Note10+ 5G - aura black - 5G smartphone - 512 GB - TD-SCDMA / UMTS / GSM | Product Type | 5G smartphone | Manufacturer Model Number | SM-N976B | Display | OLED display - 3040 x 1440 pixels - 6.8" - 498 ppi - Infinity-O Dynamic AMOLED - HDR | Features | Heart rate sensor | Processor | Samsung Exynos 9 9825 / 2.7 GHz (8-core) - 64-bit | Memory | RAM 12 GB / 512 GB | Supported Memory Card | microSDXC slot - up to 1 TB | Operating System | Android 9.0 Pie | Main Camera | 16 Megapixel - ultra wide-angle lens - 2x optical zoom - f/2.2 - focus: automatic | Second Camera | 12 Megapixel - telephoto lens - f/1.5 & f/2.4 | Third Camera | 12 Megapixel - f/2.1 | Fourth Camera | 0.3 Megapixel - depth camera | Front Camera | 10 Megapixel f/2.2 - automatic | Service Provider | Not specified | SIM Card | Single-SIM - nano SIM | Wireless Interface | NFC, Wi-Fi 5, Bluetooth, ANT+, Wi-Fi 6 | Security Devices | Fingerprint reader (under display), face recognition | Messaging Services | SMS, MMS | Connectors | USB-C | Talk Time | Up to 1680 minutes | Wireless Charging Standards | WPC, PMA | Protection | Dustproof, splashproof, waterproof | Colour | Aura black | Dimensions (WxDxH) | 77.2 mm x 7.9 mm x 162.3 mm | Weight | 198 g | Specific Absorption Rate (SAR) | 0.187 W/kg (head) , 1.404 W/kg (body) | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Integrated Components | Heart rate sensor |
Width | 77.2 mm |
Depth | 7.9 mm |
Height | 162.3 mm |
Weight | 198 g |
Body Colour | Aura black |
SAR Value | 1.404 W/kg (body), 0.187 W/kg (head) |
Cellular | |
Technology | TD-SCDMA / WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 5G |
Intelligent Assistant | Bixby |
Navigation | GPS, GLONASS, BeiDou, Galileo |
SIM Card Type | Nano SIM |
SIM Card Qty | Single-SIM |
Payment Technology | Samsung Pay |
Input Device | Multi-touch |
Messaging & Internet | |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA, 5G NR FR1 |
2G Band | 850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X, 2100 CDMA2000 1X (AWS) |
3G UMTS Band | Band 1, Band 2, Band 4, Band 5, Band 8 |
3G UMTS Frequency | 2100, 1900, 1700, 850, 900 |
4G LTE Band | Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66 |
4G LTE Frequency | FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3 |
5G NR Band | N78 |
5G NR Frequency | TDD TD 3500 |
Wireless Interface | NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+, IEEE 802.11a/b/g/n/ac/ax |
Phone Features | |
Phone Functions | Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert |
Sensors | Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor |
Additional Features | S Pen multi-input, Face Unlock, Wi-Fi Miracast, Screen Write, Smart Select, MU-MIMO technology, Fast Charging, Samsung KNOX, Face recognition, High AOP Mic, Smart View, Live message, Screen off memo, Samsung DeX support, Bixby Vision, Smart Performance Adjuster, Dual Audio, water-carbon cooling system, S Pen remote function |
Media Player | |
Supported Digital Audio Standards | WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, apt-X, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128 |
Supported Digital Video Standards | MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2 |
Sound Enhancements | Dolby Digital Plus sound, Dolby Atmos sound technology, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound |
Processor | |
Type | Samsung Exynos 9 |
Processor Number | 9825 |
Clock Speed | 2.7 GHz |
Processor Core Qty | 8-core |
64-bit Architecture | Yes |
Memory | |
RAM | 12 GB |
Internal Memory Capacity | 512 GB |
User Memory | 461.4 GB |
Supported Flash Memory Cards | microSDHC, microSDXC - up to 1 TB |
Front Camera | |
Sensor Resolution | 10 Megapixel |
Lens Aperture | F/2.2 |
Focus Adjustment | Automatic |
Field of View (FoV) | 80 degree(s) |
Special Effects | HDR, Grid Line |
Camera Modes | Timer mode, wide selfie mode, selfie mode, Live Focus mode, AR Emoji, selfie focus, Live focus video |
Features | Quick launch, Motion photo, Stamps, location tags, VDIS (Video Digital Image Stabilization), Full view, Flaw detection, Dual Pixel AF |
Main Camera | |
Sensor Resolution | 16 Megapixel |
Lens Type | Ultra wide-angle lens |
Field of View (FoV) | 123 degree(s) |
Pixel Size | 1 µm |
Optical Zoom | 2x |
Digital Zoom | 10x |
Special Effects | HDR, Bokeh effect, Grid Line |
Camera Modes | Panorama, Pro mode, Timer mode, HYPERLAPSE, Auto mode, Food mode, Super Slow-mo, AR Emoji, Portraits, Flowers, Indoor scenes, Animals, Landscapes, Greenery, Trees, Sky, Mountains, Beaches, Sunrises and sunsets, Watersides, Street scenes, Night scenes, Waterfalls, Snow, Birds, Backlit, Text, Disney AR Emoji |
Face Detection | Face detection |
Light Source | LED flash |
Video Resolutions | 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps |
Features | Quick Launch, Playback zoom, Motion photo, VDIS (Video Digital Image Stabilisation), Live Focus, Dual Capture, High CRI LED flash, Tracking AF, Video location tags, Stamps, location tags, Continuous autofocus video, Hyperlapse video support 1080p, Live focus with bokeh filters, Super Speed Dual Pixel, background blur, Scene Optimiser, Eye blink, Motion blur, Lens smudge, Backlit, Full view, Flaw detection, 9.1MP still photos recording 4K video, Super Speed Dual Pixel AF |
Second Camera | |
Sensor Resolution | 12 Megapixel |
Lens Type | Telephoto lens |
Lens Aperture | F/1.5 & f/2.4 |
Pixel Size | 1.4 µm |
Features | OIS (Optical Image Stabilisation) |
Third Camera | |
Optical Image Stabiliser | Optical Image Stabiliser (OIS) |
Lens Aperture | F/2.1 |
Field of View (FoV) | 45 degree(s) |
Pixel Size | 1 µm |
Features | Phase Detect Auto-Focus (PDAF) |
Fourth Camera | |
Sensor Resolution | 0.3 Megapixel |
Functions | Depth camera |
Display | |
Type | OLED display |
Technology | Infinity-O Dynamic AMOLED |
Diagonal Size | 6.8" |
Display Resolution | 3040 x 1440 pixels |
Display Format | QHD+ |
Pixel Density | 498 ppi |
Max Brightness | 1200 cd/m² |
Colour Depth | 16.7 million colours |
HDR | Yes |
HDR Technology | HDR10+ |
Contrast Ratio | 2000000:1 |
Features | Always-on display, Edge Screen, DCI-P3 Wide colour gamut, Infinity Display, Edge-to-Edge screen |
Connections | |
Connector Type | USB Type-C |
Battery | |
Capacity | 4300 mAh |
Fast Charging Technology | Qualcomm Quick Charge 2.0, Samsung Super Fast Charging 2.0 |
Wireless Charging | Yes |
Talk Time | 1680 minutes |
Run Time Details | Talk (4G): up to 1680 min , Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (audio): up to 61 hrs , Playback (video): up to 19 hrs |
Miscellaneous | |
Compliant Standards | IP68 |
Included Accessories | Power adapter, tweezer, SIM card removal tool, USB-C cable, S Pen, Pen nibs, clear cover case, protective film, Earphones (USB Type-C) with sound by AKG |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Max Depth of Water Resistance | 1.5 m |
