Unbox Your Phone!
Introducing the stunning Infinity display. The revolutionary design of the Galaxy S8 begins from the inside out. Samsung rethought every part of the phone's layout to break through the confines of the smartphone screen. So all you see is pure content and no bezel. It's the biggest, most immersive screen on a Galaxy smartphone of this size. And it's easy to hold in one hand. Immerse yourself in a bigger view that still fits comfortably in your hand. Galaxy S8 break free from the confines of bezels, offering a smooth, uninterrupted surface that flows seamlessly over the edges. To do this, Samsung completely redesigned the phone from the inside out and also embedded the home button under the screen, where it stays hidden until you need it. So you get a bigger, unobstructed view without a larger phone.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Samsung Galaxy S8+ - orchid grey - 4G smartphone - 64 GB - TD-SCDMA / UMTS / GSM | Product Type | 4G smartphone | Manufacturer Model Number | SM-G955F | Display | OLED display - 2960 x 1440 pixels - 6.2" - 529 ppi - Quad HD+ Super AMOLED | Features | Heart rate sensor | Processor | Samsung Exynos 8895 (8-core) - 64-bit | Graphics Accelerator | Mali-G71 MP20 | Memory | RAM 4 GB / 64 GB | Supported Memory Card | microSDXC slot - up to 256 GB | Operating System | Android 7.0 Nougat | Main Camera | 12 Megapixel - f/1.7 - focus: automatic, manual | Front Camera | 8 Megapixel - CMOS f/1.7 - automatic | Service Provider | Not specified | SIM Card | Single-SIM - nano SIM | Wireless Interface | NFC, Wi-Fi 5, Bluetooth, ANT+/ANT | Security Devices | Fingerprint reader, eye scan | Messaging Services | SMS, MMS | Connectors | 3.5 mm headset jack, USB-C | Talk Time | Up to 1440 minutes | Wireless Charging Standards | WPC, PMA | Protection | Dustproof, splashproof, waterproof | Colour | Orchid grey | Dimensions (WxDxH) | 73.4 mm x 8.1 mm x 159.5 mm | Weight | 173 g | Specific Absorption Rate (SAR) | 0.26 W/kg (head) , 1 W/kg (body) | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Integrated Components | Heart rate sensor |
Width | 73.4 mm |
Depth | 8.1 mm |
Height | 159.5 mm |
Weight | 173 g |
Body Colour | Orchid grey |
SAR Value | 1 W/kg (body), 0.26 W/kg (head) |
Cellular | |
Technology | TD-SCDMA / WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Intelligent Assistant | Bixby |
Navigation | GPS, A-GPS, GLONASS, BeiDou, Galileo |
SIM Card Type | Nano SIM |
SIM Card Qty | Single-SIM |
Payment Technology | Samsung Pay |
Input Device | Multi-touch |
Messaging & Internet | |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE |
2G Band | 850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X, 2100 CDMA2000 1X (AWS) |
3G UMTS Band | Band 1, Band 2, Band 4, Band 5, Band 8 |
3G UMTS Frequency | 2100, 1900, 1700, 850, 900 |
4G LTE Band | Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66 |
4G LTE Frequency | FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3 |
Wireless Interface | NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT |
Bluetooth Profiles | HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP |
Phone Features | |
Phone Functions | Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert |
Sensors | Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, heart rate, pressure sensor, geomagnetic sensor |
Additional Features | Wi-Fi Miracast, MU-MIMO technology, Fast Charging, Samsung KNOX |
Media Player | |
Supported Digital Audio Standards | WAV, WMA, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, apt-X, DSF, DSD, MXMF, IMY, RTTTL, RTX, OTA, DFF, MID |
Supported Digital Video Standards | MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2 |
Processor | |
Type | Samsung Exynos |
Processor Number | 8895 |
Processor Core Qty | 8-core |
64-bit Architecture | Yes |
Graphics System | |
Memory | |
RAM | LPDDR4 SDRAM - 4 GB |
Internal Memory Capacity | 64 GB |
User Memory | 52.3 GB |
Supported Flash Memory Cards | microSDHC, microSDXC - up to 256 GB |
Front Camera | |
Sensor Resolution | 8 Megapixel |
Sensor Type | CMOS |
Sensor Size | 1/3.6" |
Lens Aperture | F/1.7 |
Focus Adjustment | Automatic |
Camera Modes | Wide selfie mode |
Main Camera | |
Sensor Resolution | 12 Megapixel |
Sensor Size | 1/2.55" |
Optical Image Stabiliser | Optical Image Stabiliser (OIS) |
Focus Adjustment | Automatic, manual |
Digital Zoom | 8x |
Special Effects | HDR, Bokeh effect |
Camera Modes | Panorama, Slow motion mode, Pro mode, Timer mode, Virtual Shot, HYPERLAPSE, Food mode |
Face Detection | Face detection |
White Balance | Custom, automatic |
Light Source | LED flash |
Video Resolutions | 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps |
Features | Selective Focus, Quick Launch, Playback zoom, Dual Pixel technology, Motion photo, Exposure, Shutter speed, geotagging, RAW image capture, VDIS (Video Digital Image Stabilisation) |
Display | |
Type | OLED display |
Technology | Quad HD+ Super AMOLED |
Diagonal Size | 6.2" |
Display Resolution | 2960 x 1440 pixels |
Pixel Density | 529 ppi |
Colour Depth | 16.7 million colours |
Features | Always-on display |
Connections | |
Connector Type | USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm |
Battery | |
Capacity | 3500 mAh |
Wireless Charging | Yes |
Talk Time | 1440 minutes |
Run Time Details | Talk (WCDMA): up to 1440 min , Playback (MP3 (AOD on)): up to 50 hrs , Playback (MP3 (AOD off)): up to 78 hrs , Playback (video): up to 18 hrs , Active online usage (Wi-Fi): up to 15 hrs , Active online usage (3G): up to 13 hrs , Active online usage (LTE): up to 15 hrs |
Miscellaneous | |
Compliant Standards | IP68 |
Included Accessories | Power adapter, SIM card removal tool, AKG headphones, micro-USB connector (C to B), ear plugs, USB-C to A connector, USB-C cable |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Max Depth of Water Resistance | 1.5 m |
