Samsung Travel Power Adapter EP-TA20U (AC / USB - 2000 mA (USB (power only)) - White
Don’t risk running out of power when you need your mobile the most. The portable design of the Samsung Flat TA Charger allows you to keep it handy while at home or at the office. Always be sure that your Samsung Galaxy or other micro USB compatible Device is always fully charged and ready to go.
Includes micro-USB cable
Product Description | Samsung Travel Adapter EP-TA20U power adapter - USB | Product Type | Power adapter | Dimensions (WxDxH) | 4.915 cm x 6.865 cm x 2.8 cm | Weight | 55.5 g | Colour | White | Output Connector Type | USB | Voltage Provided | 5 V | Max Electric Current | 2000 mA | Cables | USB cable |
General | |
Width | 4.915 cm |
Depth | 6.865 cm |
Height | 2.8 cm |
Weight | 55.5 g |
Enclosure Colour | White |
Power Device | |
Input Connectors | Power 2-pole |
Input Connectors Qty | 1 |
Output connectors | 4 pin USB Type A |
Miscellaneous | |
Cables Included | USB cable |
