Samsung PRO Endurance MB-MJ128GA Flash memory card (microSDXC to SD adapter included) 128 GB - UHS-I U1 / Class10 microSDXC UHS-I
Product Description | Samsung PRO Endurance MB-MJ128GA - flash memory card - 128 GB - microSDXC UHS-I | Product Type | Flash memory card | Form Factor | microSDXC UHS-I Memory Card | Storage Capacity | 128 GB | Speed Rating | UHS-I U1 / Class10 | Included Memory Adapter | microSDXC to SD adapter | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Speed Class | UHS-I U1 / Class10 |
Read Rate | Up to 100 MB/s |
Write Rate | Up to 30 MB/s |
Features | Magnetic-proof, waterproof, X-ray-proof, temperature-proof |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 15 mm |
Height | 11 mm |
Thickness | 1 mm |
Weight | 0.5 g |
Environmental Parameters | |
Min Operating Temperature | -25 °C |
Max Operating Temperature | 85 °C |
Humidity Range Operating | 0 - 93% |
