Know when there’s a water leak in your home.
Add smartness to your home with a SmartThings Water Leak Sensor. Receive alerts or set connected devices to turn on or off when moisture is detected. Also monitors temperature.
SmartThings is the easy way to turn your home into a smart home.
In the Box
Requirements
Technical Information
Product Description | Samsung SmartThings - water leak sensor - ZigBee 3.0 - white | Product Type | Water leak sensor | Functions | Water leak detection | Power Source | Battery | Internet of Things (IoT) Platform | SmartThings | Connectivity | Wireless - ZigBee 3.0 | Colour | White | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 5.9 cm x 2 cm x 4.2 cm |
General | |
Connectivity Technology | Wireless - ZigBee |
Max Range Indoors | 40 m |
OS Required | Android 6.0 (Marshmallow) or later, Apple iOS 11 or later |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Battery | |
Form Factor | CR2 |
Battery Included | Yes |
Required Qty | 1 |
Miscellaneous | |
Colour | White |
Dimensions & Weight | |
Width | 5.9 cm |
Depth | 2 cm |
Height | 4.2 cm |
Weight | 49 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
