Multi-Speaker Control Technology
Wireless Surround Sound Technology
2.0 Channel
6 Speaker Soundbar
450W
Get real, with HD Audio
Feel the sound and get into the action with stunningly realistic HD Audio. It preserves the quality and richness of the original sound through 96kHz/24 bit without down sampling.
Multi-speaker control
Get the ultimate sound experience. Powered by exclusive Samsung technology, multi-array speakers move simultaneously for more powerful bass.
Sweet spot anywhere you sit
Every spot is the sweet spot. Get consistently amazing sound everywhere in the room with the state-of-the-art Wide-range tweeter.
Product Description | Samsung HW-MS550 - sound bar - for home theatre - wireless | Product Type | Sound bar - for home theatre - 2.0-channel | Speaker Type | Active | Amplifier | Integrated | Interfaces | Bluetooth, Wi-Fi | Audio Formats | WAV, AAC, MP3, FLAC, OGG, ALAC | Colour | Black | Built-in Decoders | Dolby Digital, DTS decoder | Dimensions (WxDxH) | 89 cm x 13.05 cm x 7.1 cm | Weight | 5 kg |
General | |
Enclosure Colour | Black |
Speaker System | |
Maximum Sampling Rate Supported | 96 kHz |
High-Resolution Audio | Yes |
Multiroom | Yes |
Recommended Placing | Wall-mountable, under-the-TV |
Connections | |
Connector Type | HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link) |
Miscellaneous | |
Included Accessories | Digital audio cable (optical), remote control, wall mounting bracket |
Dimensions & Weight | |
Width | 89 cm |
Depth | 13.05 cm |
Height | 7.1 cm |
Weight | 5 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 112.6 cm |
Shipping Depth | 22.6 cm |
Shipping Height | 14.8 cm |
Shipping Weight | 7.5 kg |
