Rugged design with a sense of sophistication. At a slim 9.7mm wide, the Galaxy Xcover4 is thinner than previous generations and features an easy-to-grip, non-slip finish. It won’t slide out of your hand unexpectedly while on the go.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Samsung Galaxy Xcover 4 - black - 4G smartphone - 16 GB - GSM | Product Type | 4G smartphone | Manufacturer Model Number | SM-G390F | Display | LCD display - 1280 x 720 pixels - 5" - TFT | Processor | 1.4 GHz (quad-core) | Memory | RAM 2 GB / 16 GB | Supported Memory Card | microSDXC slot - up to 256 GB | Operating System | Google Android | Main Camera | 13 Megapixel - CMOS - f/1.9 - focus: automatic | Front Camera | 5 Megapixel - CMOS f/2.2 | Service Provider | Not specified | Form Factor | Rugged | SIM Card | Single-SIM - micro SIM | Wireless Interface | NFC, Wi-Fi, Bluetooth | Messaging Services | SMS, MMS | Connectors | 3.5 mm headset jack, Micro-USB | Talk Time | Up to 1020 minutes | Protection | Dustproof, splashproof, waterproof | Colour | Black | Dimensions (WxDxH) | 73.3 mm x 9.7 mm x 146.2 mm | Weight | 172 g | Specific Absorption Rate (SAR) | 0.611 W/kg (head) , 1.24 W/kg (body) |
General | |
Product Type | Smartphone |
Form Factor | Touch - Rugged |
Width | 73.3 mm |
Depth | 9.7 mm |
Height | 146.2 mm |
Weight | 172 g |
Body Colour | Black |
SAR Value | 1.24 W/kg (body), 0.611 W/kg (head) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Navigation | GPS, GLONASS, BeiDou |
SIM Card Type | Micro SIM |
SIM Card Qty | Single-SIM |
Input Device | Multi-touch |
Messaging & Internet | |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE |
2G Band | 850 GSM, 900 GSM, 1800 GSM, 1900 GSM |
3G UMTS Band | Band 1, Band 2, Band 5, Band 8 |
3G UMTS Frequency | 2100, 1900, 850, 900 |
4G LTE Band | Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 38, Band 40 |
4G LTE Frequency | FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, TDD 2600, TDD 2300 |
Wireless Interface | NFC, IEEE 802.11a/b/g/n, Bluetooth 4.2 |
Bluetooth Profiles | HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP |
Phone Features | |
Phone Functions | Speakerphone, call timer, conference call, flight mode, vibrating alert |
Sensors | Accelerometer, ambient light sensor, proximity sensor, geomagnetic sensor |
Media Player | |
Supported Digital Audio Standards | WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID |
Supported Digital Video Standards | MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2 |
Processor | |
Clock Speed | 1.4 GHz |
Processor Core Qty | Quad-core |
Memory | |
RAM | 2 GB |
Internal Memory Capacity | 16 GB |
User Memory | 10.1 GB |
Supported Flash Memory Cards | microSDHC, microSDXC - up to 256 GB |
Front Camera | |
Sensor Resolution | 5 Megapixel |
Sensor Type | CMOS |
Lens Aperture | F/2.2 |
Main Camera | |
Sensor Resolution | 13 Megapixel |
Lens Aperture | F/1.9 |
Focus Adjustment | Automatic |
Light Source | Flash |
Video Resolutions | 1920 x 1080 (1080p) at 30 fps |
Display | |
Type | LCD display |
Technology | TFT |
Diagonal Size | 5" |
Display Resolution | 1280 x 720 pixels |
Display Format | HD |
Colour Depth | 16.7 million colours |
Connections | |
Connector Type | Headset jack - mini-phone 3.5mm , Micro-USB - 5 pin Micro-USB Type B |
Battery | |
Capacity | 2800 mAh |
Talk Time | 1020 minutes |
Run Time Details | Active online usage (3G): up to 11 hrs , Active online usage (LTE): up to 14 hrs , Active online usage (Wi-Fi): up to 14 hrs , Playback (video): up to 13 hrs , Playback (audio): up to 77 hrs , Talk (WCDMA): up to 1020 min |
Miscellaneous | |
Compliant Standards | IEC 60529 IP68 |
Included Accessories | Power adapter |
