We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
With write speeds of up to 150MB/s, the SanDisk Extreme Go USB 3.1 Flash Drive lets you quickly copy and go. Up to 35X faster than standard USB 2.0 drives, so you can transfer a full-length 4K movie to the drive in less than 40 seconds . The design keeps the retractable connector protected when not in use, and the included SanDisk SecureAccess software provides password protection of your private files while leaving the rest of the drive available for sharing.SanDisk products are constructed to the highest standards and rigorously tested. You can be confident in the outstanding quality, performance and reliability of every SanDisk product.
Product Description | SanDisk Extreme Go - USB flash drive - 128 GB | Product Type | USB flash drive | Interface Type | USB 3.1 | Storage Capacity | 128 GB | Localisation | Latin America, Asia Pacific, Middle East, Africa, Europe | Software Included | SanDisk SecureAccess |
General | |
Memory | |
Read Rate | Up to 200 MB/s |
Write Rate | Up to 150 MB/s |
Features | Retractable connector |
Software / System Requirements | |
Dimensions & Weight | |
Width | 70.87 mm |
Depth | 21.34 mm |
Height | 11.43 mm |
Weight | 18.14 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
