Get to Your Files Faster
The SanDisk Ultra USB 3.0 Flash Drive combines faster data speeds and generous capacity in a compact, stylish package. With transfer speeds of up to 80MB/s, this USB 3.0 flash drive can move files up to four times faster than USB 2.0 drives**Read speeds up to 4 times faster than Cruzer® USB 2.0 drives at up to 80MB/sec. USB 3.0 port required. Based on internal testing using a USB 3.0 compatible host; performance will vary depending on host device. 1MB=1,000,000 bytes.. With storage capacities up to 64GB, the drive can accommodate your bulkiest media files and documents.
Move Files Quickly with Faster Transfer Speeds
With transfer speeds of up to 80MB/s**Read speeds up to 4 times faster than Cruzer® USB 2.0 drives at up to 80MB/sec. USB 3.0 port required. Based on internal testing using a USB 3.0 compatible host; performance will vary depending on host device. 1MB=1,000,000 bytes., the SanDisk Ultra USB 3.0 Flash Drive reduces the time you'll spend waiting for files to move from the flash drive to your computer. Enabled for USB 3.0 ports, the drive lets you transfer, store, and share large files up to four times faster than USB 2.0 drives**Read speeds up to 4 times faster than Cruzer® USB 2.0 drives at up to 80MB/sec. USB 3.0 port required. Based on internal testing using a USB 3.0 compatible host; performance will vary depending on host device. 1MB=1,000,000 bytes..
High-Capacity Drive Accommodates Large Files
Offered in capacities up to 64GB**1 GB=1,000,000,000 bytes. Actual user storage less., the SanDisk Ultra USB 3.0 Flash Drive can hold all your favorite media and important documents, including high-resolution photos, MP3s, HD**HD (1280x720) video support may vary based on host device, file attributes and other factors. See www.sandisk.com/HD movies, presentations, and graphic files.
Stylish, Portable Design
With its sleek black design, the SanDisk Ultra USB 3.0 Flash Drive is as stylish as it is practical. This compact and portable drive can easily travel with you in a pocket or handbag.
SanDisk SecureAccess Software Keeps Files Private
The SanDisk Ultra USB 3.0 Flash Drive includes SanDisk SecureAccess software, which lets you set up a password-protected private folder on your drive**Password protection uses 128-bit AES encryption and is supported by Windows® XP, Windows Vista®, Windows 7, Windows 8, and Mac OS X v10.5+ (Software download required for Mac, see www.SanDisk.com/SecureAccess). Your files will be secured with 128-bit AES encryption to help keep them confidential, even when sharing the drive with others.
Warranty
The SanDisk Ultra USB 3.0 Flash Drive is backed by a five-year limited warranty**See www.sandisk.com/wug for additional information..
Product Description | SanDisk Ultra - USB flash drive - 32 GB | Product Type | USB flash drive | Interface Type | USB 3.0 | Storage Capacity | 32 GB | Encryption Algorithm | 128-bit AES | Localisation | Europe | Software Included | SanDisk RescuePRO, SanDisk SecureAccess | OS Required | Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Windows 8 | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 130 MB/s |
Write Rate | Up to 60 MB/s |
Features | Password protection, retractable connector, key ring loop |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Compliant Standards | AES-128 |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 21.3 mm |
Depth | 56.8 mm |
Height | 10.8 mm |
Weight | 9 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 101.6 mm |
Shipping Depth | 152.4 mm |
Shipping Height | 11.9 mm |
Shipping Weight | 32.8 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
