We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
For everything NAS, there's IronWolf. Always on and always working, IronWolf is enhanced with AgileArray technology for optimal reliability and system agility. Multi-user technology and extreme workload rates allow IronWolf to perform and scale up with your enterprise.
A thriving small business needs storage that can thrive with it. IronWolf is optimized for NAS in multi-RAID environments that not only handle the vibration, but also handle the high user workload rate in a high data traffic network.
Product Description | Seagate IronWolf Pro ST2000NE0025 - hard drive - 2 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 2 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 128 MB | Spindle Speed | 7200 rpm | Features | Hot-Plug Support, 24x7 availability, rotation vibration sensor, AgileArray | Dimensions (WxDxH) | 101.85 mm x 146.99 mm x 26.11 mm | Weight | 550 g | Manufacturer Warranty | 5-year warranty | Bundled with | Seagate Rescue Data Recovery |
General | |
Device Type | Hard drive - internal |
Capacity | 2 TB |
Bytes per Sector | 512 |
Width | 101.85 mm |
Depth | 146.99 mm |
Height | 26.11 mm |
Weight | 550 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 195 MBps |
Average Latency | 4.16 ms |
Reliability | |
MTBF | 1,200,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^15 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 4.5 Watt (idle) , 7.5 Watt (active) , 0.8 Watt (standby) , 0.8 Watt (sleep) |
Miscellaneous | |
Compliant Standards | ICES-003 Class B, NMB-3 Class B |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years , Insurance - data recovery - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 70 g @ 2 ms |
Shock Tolerance (non-operating) | 300 g @ 2 ms |
Vibration Tolerance (non-operating) | 5 g @ 10-500 Hz |
