With the Somfy Indoor Camera nothing will escape you again, because this Full HD plug and play Indoor camera records everything and sends you a push message if there is something suspicious going on. The great thing is that you can install the camera in under 10 minutes and you can set it to communicate with your smartphone via the app - it looks great too!
The camera starts recording as soon as it detects movement, you get a push message on your smartphone and you can view the images live or rewind by 10 seconds, all recordings are stored in the cloud for later viewing.
The Somfy Indoor camera is future proof and fully compatible with a width range of services like Google assistant, Amazon Alexa, IFTTT.
And then there’s the privacy shutter, as soon as you enter the room, the camera literally closes down, so everything you do in the privacy of your own home is for your eyes only. Nothing gets recorded, nothing gets stored on the cloud, zippo, niente, nada. 100% privacy guaranteed.
Finally. Have you got pets who are free to wander around? You can set up the camera in such a way that not all movements activate it.
Features:
Product Description | Somfy Indoor Camera - network surveillance camera | Device Type | Network surveillance camera - fixed - indoor | Audio | Yes: built-in speaker, built-in microphone | Dimensions (WxDxH) | 9 cm x 9 cm x 4.3 cm | Weight | 170 g | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Frame Rate (max) | 30 frames per second | Motion Detection | Yes | Video Modes | 1080p | Focal Length Control | Fixed focal | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Platform | Apple HomeKit, Nest, IFTTT, Somfy TaHoma | Intelligent Assistant | Google Assistant, Alexa | Cables Included | 1 - micro-USB cable - external - 3 m | Voltage | DC 5 V | Features | Infrared cut filter | Manufacturer Warranty | 2-year warranty | Environmental Parameters (operating) | 0 °C - 45 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, built-in microphone |
Width | 9 cm |
Depth | 9 cm |
Height | 4.3 cm |
Weight | 170 g |
Camera | |
Type | Colour - Day&Night - fixed - indoor |
Digital Zoom | 8 |
Infrared LEDs | Yes |
Infrared Distance | 6 m |
Lens Construction | |
Type | Fixed focal |
Horizontal Field of View (degree) | 130 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Miscellaneous | |
Included Accessories | Table stand |
Cables Included | 1 x micro-USB cable - external - 3 m |
Power | |
Power Requirements | DC 5 V |
Power Device | Power adapter |
Internet of Things (IoT) | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
