High Definition Sound
The smart, compact soundbar for TV, music, and more.
Experience incredible sound while streaming music, watching TV and movies, enjoying podcasts and audiobooks, or playing video games all with voice control via the Google Assistant or Amazon Alexa.
Hear every word clearly
Beam was specifically tuned by Oscar-winning sound engineers to emphasise the sound of the human voice so you can always follow the story.
Voice control
The Google Assistant and Amazon Alexa are built right-in so you can play music, check news, set alarms, get your questions answered, and more, completely hands-free.
Setup is simple
Go from unboxing to listening in minutes with just two cables and automatic remote detection.
Night Sound
Enjoy late night TV without ever waking the whole house.
Speech Enhancement
Turn on dialog clarity speech enhancement and never miss another word.
Build your system
Easily connect Sonos speakers in different rooms over WiFi to create a home sound system that brings every room and everyone together.
Brilliant sound
Enjoy clear, richly detailed sound that fills the room at any volume.
Easy to use
Setup takes minutes, and control is simple with the Sonos app, AirPlay 2, and your voice.
Listen your way
Customise your system and play what you want, where you want.
Introducing Sonos Radio
Enjoy thousands of stations, including live radio and exclusive programming, on your system through the Sonos app.
Product Description | Sonos Beam - sound bar - wireless | Product Type | Sound bar | Features | Internet radio | Speaker Type | Active | Amplifier | Integrated | Interfaces | Ethernet, Fast Ethernet, Wi-Fi | Platform | Lutron, Wink | Intelligent Assistant | Alexa - indirect | AirPlay | Yes | Audio Formats | PCM | Colour | White | Built-in Decoders | Dolby Digital | Power | AC 120/230 V (50 - 60 Hz) | Dimensions (WxDxH) | 65.1 cm x 6.85 cm x 10 cm | Weight | 2.8 kg | Manufacturer Warranty | 2-year warranty |
General | |
Microphone | 5 microphones array |
Enclosure Colour | White |
Speaker System | |
Interfaces | IEEE 802.3 (Ethernet), IEEE 802.3u (Fast Ethernet), IEEE 802.11b/g |
AirPlay | Yes |
Recommended Placing | On-wall mounted, desktop |
Controls | Volume, play/pause, next track, previous track, mute microphone |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Communications Technology | Wi-Fi |
Intelligent Assistant | Alexa |
Voice Control | Indirect |
Speaker System Details | |
Driver Details | Sound bar: tweeter driver , Sound bar: 4 x woofer driver , Sound bar: 3 x Passive Radiator |
Connections | |
Connector Type | HDMI (19 pin HDMI Type A) , LAN (RJ-45) |
Miscellaneous | |
Included Accessories | HDMI cable, audio (optical) adapter |
Power | |
Power Source | Integrated power supply |
Voltage Required | AC 120/230 V (50 - 60 Hz) |
Dimensions & Weight | |
Width | 65.1 cm |
Depth | 6.85 cm |
Height | 10 cm |
Weight | 2.8 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
