ITEM | QTY | PRICE |
TCL 32" 32S5200K HD Smart Androi...
4 | £556.00 |
StarTech.com USB-C to Gigabit Adapter
4 | £118.08 |
StarTech.com 2-Port 2.5G PCIe Network...
4 | £672.08 |
Fractions of a second matter. The incredibly fast refresh rate of the INZONE M3 puts you a step ahead of your competitors and lets you speed through scenes without lag, delay or judder.
React faster than your opponents. With a refresh rate of up to 240 Hz, you'll gain that vital split-second advantage that helps you track rivals precisely and shoot first. Action is super smooth in Full HD so you see what's happening the moment it happens.
Product Description | Sony INZONE M3 - LED monitor - Full HD (1080p) - 27" - HDR | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class E | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 240 Hz | Brightness | 400 cd/m² | Contrast Ratio | 1000:1 / 1000:1 (dynamic) | HDR Capable | HDR10 / DisplayHDR 400 | Response Time | 1 ms | Colour Support | 1.07 billion colours | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50 - 60 Hz) | Dimensions (WxDxH) - without stand | 61.5 cm x 7.3 cm x 36.3 cm | Weight | 4.1 kg | Manufacturer Warranty | 1-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 27" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
HDR Format | HDR10 |
HDR Certification | DisplayHDR 400 |
Vertical Refresh Rate | 24 - 240 Hz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Japanese, Korean |
Features | Eco-Mode, game mode, Cinema Mode, Black eQualizer, FPS Mode, Flicker Free technology, Crosshair Display, Low Blue Light technology |
Dimensions (WxDxH) | 61.5 cm x 7.3 cm x 36.3 cm - without stand |
Weight | 4.1 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 4 Watt |
Connectivity | |
Interfaces | 2 x HDMI (HDCP) , DisplayPort 1.4 (HDCP) , USB upstream (Type B) , USB upstream (Type A) , 3 x USB downstream (Type A) , Headphones (mini-jack) |
Mechanical | |
Tilt Angle | 0/+20 |
Height Adjustment | 70 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50 - 60 Hz) |
Power Consumption SDR (On mode) | 21.6 kWh/1000h |
Power Consumption HDR (On mode) | 31.1 kWh/1000h |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 61.5 cm - depth: 7.3 cm - height: 36.3 cm , With stand - width: 61.5 cm - depth: 24.8 mm - height: 47.9 cm - weight: 6.2 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 69 cm |
Shipping Depth | 22.8 cm |
Shipping Height | 46.2 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
