More colors means more realism. A TRILUMINOS Display with its specially-developed backlight selectively maps colors across a wider gamut, ensuring subtle colors do not become oversaturated and unnatural. You'll enjoy vivid, authentic images that evoke the emotion in every scene. Discover a thrilling world of extraordinary clarity with every single pixel enhanced beautifully. Individual parts of each scene are analyzed and matched with a special image database that independently addresses texture, contrast, color and edges. The difference is clear with supremely lifelike detail, whatever you're watching.
Product Description | Sony Bravia KD-43XE8004 43" Class (42.5" viewable) LED-backlit LCD TV - 4K | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 43" | Diagonal Size | 42.5" | Colour | Black | Platform | Android TV | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | Input Video Formats | 480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p | Frame Rate & Enhancement Technology | Motionflow XR 100 technology, 50 Hz Refresh Rate | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 4 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | Edge-lit LED frame dimming | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2 | Internet Streaming Services | Voice Search, Chromecast, YouView | Picture Enhancements | Live Color, 4K X-Reality PRO Engine, dynamic contrast enhancement | Speaker System | 2 speakers | Sound Effects | S-FORCE Front Surround Sound, DTS Digital Surround | Storage Drive Capacity | 16 GB | Storage Capacity | 16 GB | USB | 3 ports | Included Accessories | Remote control, batteries, IR Blaster | Voltage | AC 230V (50 Hz) | Energy Class | Class A | Power Consumption Operational | 133 Watt | Power Consumption (On mode) | 70 W | Power Consumption Stand by | 0.5 Watt | Energy Consumption per Year | 97 kWh | Dimensions (WxDxH) - without stand | 96.4 cm x 5.7 cm x 56.7 cm | Weight | 10.1 kg |
General | |
Operating System | Android OS |
HDR Capable | Yes |
TV Tuner Presence | Yes |
Sensors | Light sensor |
Modes | Backlight off mode |
Design | Narrow Frame Design |
Dimensions | Without stand |
Width | 96.4 cm |
Depth | 5.7 cm |
Height | 56.7 cm |
Weight | 10.1 kg |
Enclosure Colour | Black |
Display | |
LCD Backlight Technology | Edge-lit LED - frame dimming |
Display Menu Language | Multilingual |
Features | Tv SideView, Dynamic Backlight Control, Triluminos Display |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | 100 x 200 mm |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Teletext | Yes |
Electronic Programme Guide | Digital EPG |
Closed Caption Capability | Yes |
Media Player | |
Supported Video Formats | MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, ASF, AVI, MKV, MOV, AVCHD, TS, AVC, 3GPP, PS, VC-1, WebM, HEVC, VP8 |
Supported Audio Formats | MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), ASF, MP4 |
Supported Pictures Formats | JPEG |
USB Port | Yes |
USB Ports Qty | 3 |
Configuration | 16 GB |
Remote Control | |
Type | Remote control |
Features | Voice control |
Audio System | |
Digital Audio Format | Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output |
Surround Mode | Yes |
Output Power / Total | 20 Watt |
Features | Audio Return Channel (ARC), Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, voice search, Bass Reflex Speaker System |
Speakers | 2 x speaker - 10 Watt |
Network & Internet Multimedia | |
Functionality | WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Wi-Fi Protocol | 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac |
Connect & Share | Screen Mirroring, Wi-Fi Miracast, Photo Sharing Plus, Bluetooth Human Interface Device (HID) |
Application Store | Google Play |
Connections | |
Connector Type | LAN - bottom , Composite video / component video input - bottom , Composite video input - bottom , 2 x HDMI - side , 2 x HDMI - rear , SPDIF output - rear , Audio line-out / headphones / subwoofer - rear , 3 x USB - side |
Miscellaneous | |
Included Accessories | Batteries, IR Blaster |
Compliant Standards | HDCP 2.2 |
Power | |
Power Device | Power adapter |
Input Voltage | AC 230V (50 Hz) |
Auto On/Off | Yes |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 96.4 cm x 5.7 cm x 56.7 cm x 10.1 kg , Panel with stand - 96.4 cm x 24.2 cm x 61.7 cm x 10.8 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 106 cm |
Depth (Shipping) | 15.6 cm |
Height (Shipping) | 66.4 cm |
Weight (Shipping) | 15 kg |
