ITEM | QTY | PRICE |
StarTech.com 1 Port RS232 Serial to I...
4 | £593.12 |
Samsung 2TB 980 PRO PCIe M.2 SSD
4 | £850.88 |
Our best ever noise cancelling headphones, designed for authentic perfection
With two processors controlling eight microphones, Auto NC Optimizer for automatically optimising noise cancelling based on your wearing conditions and environment, and a specially designed driver unit, WH-1000XM5 headphones with industry-leading noise cancelling rewrite the rules for distraction-free listening and call clarity.
Industry-leading noise cancellation
From airplane noise to people’s voices, our WH-1000XM5 wireless headphones with multiple microphone noise cancelling keep out more high and mid frequency sounds than ever. And with Auto NC Optimizer, noise cancelling is automatically optimised based on your wearing conditions and environment.
Multi Noise Sensor technology
With four microphones on each earcup, this is our biggest ever step forward in noise cancelling. Ambient sound is captured even more accurately for a dramatic reduction in high frequency noise. Thanks to Auto NC Optimizer, noise cancelling performance is always and automatically optimised based on wearing conditions and external environmental factors such as atmospheric pressure.
Incomparable noise cancelling
Specially developed by Sony, the Integrated Processor V1 unlocks the full potential of our HD Noise Cancelling Processor QN1. This unique combination of technology controls eight microphones to deliver unprecedented noise cancelling quality.
Specially designed 30mm driver unit
The specially designed 30mm driver unit featuring a soft edge enhances noise cancelling helping you enjoy your music precisely without ambient noise. The carbon fiber composite material realizes light weight and high rigidity dome and improves sound clarity, especially in high frequency ranges.
Enjoy High-Resolution Audio with and without wires
The WH-1000XM5 supports High-Resolution Audio and High-Resolution Audio Wireless, thanks to LDAC, our industry-adopted audio coding technology. LDAC transmits approximately three times more data than conventional Bluetooth® audio for exceptional High-Resolution Audio quality.
Real-time restoration of all your compressed files
Using Edge-AI (Artificial Intelligence), DSEE Extreme™ upscales compressed digital music files in real time. Dynamically recognising instrumentation, musical genres and individual elements of each song, it restores high range sound lost in compression.
Industry-leading call quality
Our Precise Voice Pickup Technology uses four beamforming microphones and an AI-based noise reduction algorithm to isolate your voice precisely. A newly developed wind noise reduction structure minimises wind noise during calls. Wherever you are, you’ll always hear and be heard clearly.
Multiple microphones, focused on your voice
Equipped with four beamforming microphones, these headphones are calibrated to only pick up your voice. An improved signal-to-noise ratio enables them to catch every single word, even when there’s a lot of noise around.
Ultra clear, noise-free calls
With Precise Voice Pickup Technology and advanced audio signal processing, the person on the other end of the call will hear your voice clearly, even when you are in noisy situations. Our noise reduction algorithm was developed with AI machine learning using more than 500 million voice samples to suppress ambient noise and extract your voice clearly in a wide range of environments.
All day comfort with a noiseless design
These lightweight headphones are beautifully finished in newly developed "Soft fit leather". This material fits snugly around the head with less pressure on the ears while keeping out external sounds. Our noiseless design with stepless slider, seamless swivel and hanger makes WH-1000XM5 a pleasure to wear.
Product Description | Sony WH-1000XM5 - headphones with mic | Product Type | Headphones - Bluetooth - wireless, wired - 3.5 mm jack | Recommended Use | Portable electronics | Colour | Black | Headphones Form Factor | Full size | Connectivity Technology | Wireless, wired | Wireless Technology | Bluetooth | Headphones Technology | Dynamic | Bluetooth Version | Bluetooth 5.2 | Sound Effects | Digital Sound Enhancement Engine Extreme (DSEE Extreme), Ambient Sound Mode, 360 Reality Audio | Audio Specifications | Frequency Response 4 - 40000 Hz | Active Noise Canceling | Yes | Microphones Included | 8 | Intelligent Assistant | Google Assistant, Alexa |
General | |
Weight | 250 g |
Colour | Black |
Features | Touch control |
Max Operating Distance | 10 m |
Audio Output | |
Headphones Cup Type | Closed |
Bluetooth Audio Codec | SBC, AAC, LDAC |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Serial Copy Management System (SCMS-T) |
Frequency Response | 4 - 40000 Hz |
Diaphragm | 30 mm |
Magnet Material | Neodymium |
Features | HD Noise Canceling Processor QN1, Google Fast Pair, Quick Attention function, Atmospheric Pressure Optimising, Microsoft Swift Pair, Speak-to-Chat |
Microphone | |
Form Factor | Built-in |
Connections | |
Connector Type | USB (power only) , Bluetooth , Headphones (mini-phone stereo 3.5 mm) |
Cable | |
Detachable Cable | Yes |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Included Accessories | Carrying case, USB charge cable, headphones cable (1.2 m) |
Cable Details | USB charge cable - detachable , Audio cable - detachable - L shaped / mini-phone stereo 3.5 mm - 1.2 m |
Compliant Standards | JEITA |
Power | |
Battery | Headphone battery rechargeable |
Run Time (Up To) | 32 hour(s) |
Run Time Details | Continuous playback (active noise-cancelling on): up to 24 hours , Continuous playback (active noise-cancelling off): up to 32 hours |
Recharge Time | 3.5 hour(s) |
