StarTech.com 0.3m SATA Extension Cable
£7.70
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by a StarTech.com lifetime warranty
  • Eliminates the need to bend or strain the cable to account for a lack of space
  • Length: 30cm
  • Stock Status: In Stock
Product codes
Extend SATA Data Connections by up to 30cm (12in). The SATAEXT30CM 0.3-meter (30cm) SATA Data Extension Cable enables you to extend the reach between internal SATA drive connections by up to 30 cm (11.81 in).
The extension simplifies drive installation by overcoming typical connection limitations, and it reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary connection.
Product Description StarTech.com 0.3m SATA Extension Cable - 30cm 7 pin SATA Extension - 7 pin SATA Extension Cable - 7 pin SATA Extension cord - SATA extension cable - 30 cm
Type SATA extension cable
Interface Speed Serial ATA 150/300/600
Length 30 cm
Connector 7 pin Serial ATA - plug
Connector (Second End) 7 pin Serial ATA - receptacle
Colour Red
Designed For P/N: SATA18RA1
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.3m SATA...
£7.70
