The wide selection of Cat 5e patch cables makes it easy to find the lengths and colors that you need to complete your network connections.
These Ethernet cables are:
Product Description | StarTech.com 0.5m Gray Cat5e / Cat 5 Snagless Ethernet Patch Cable 0.5 m - patch cable - 50 cm - grey | Type | Patch cable - CAT 5e | Technology | Unshielded twisted pair (UTP) | Features | Snagless, stranded, PoE ready | Length | 50 cm | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Grey | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 5e |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Plated Connector | Copper |
Length | 50 cm |
Weight | 26 g |
Colour | Grey |
Connectivity | |
Miscellaneous | |
Compliant Standards | Up to 350 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
