StarTech.com 0.5m Purple Cat6 Patch Cable
£5.84
10 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • RJ45 connector-clip protectors eliminate cable snags and breaks during installation
  • Purple PVC jacket for color coding your connections
  • 50 cm in length for shorter connections, without the clutter of excess cable
  • Moulded RJ45 connectors prevent cable damage and also provide strain relief
  • 50-micron gold-plated connectors for a clear signal
  • High-quality 24 AWG copper wire
  • Length: 50cm, <1m
  • Colour: Purple
Product codes
chevron icon
chevron icon
StarTech.com N6PATC50CMPL. Cable length: 0.5 m, Cable standard: Cat6, Connector 1: RJ-45. Weight: 26 g. Package width: 200 mm, Package depth: 220 mm, Package height: 10 mm
chevron icon
Product Description StarTech.com 50cm CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Purple, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC50CMPL) - network cable - 50 cm - purple
Type Network cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Wires per Cable 8 wires
Features Snagless, stranded, PoE ready
Length 50 cm
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Purple
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£5.84
