Connect USB 2.0 peripherals to your computer
The USB2HAB50CM 0.5-meter USB A-to-B cable features one USB ''A'' male connector and one USB ''B'' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives. Constructed of only top quality materials and expertly designed for durability, this USB 2.0 A-B cable is backed by StarTech.com''s Lifetime Warranty.
The StarTech.com Advantage
Product Description | StarTech.com 0.5m USB 2.0 A to B Cable M/M - USB cable - USB to USB Type B - 50 cm | Type | USB cable | Length | 50 cm | Connector | 4 pin USB Type A - male | Connector (Second End) | 4 pin USB Type B - male | Compliant Standards | USB / USB 2.0 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 24/28 |
Length | 50 cm |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
