ITEM | QTY | PRICE |
Epson Black Fabric Ribbon for FX2190
4 | £49.28 |
TP LINK CPE510 Pharos Outdoor 5Ghz 13...
4 | £196.64 |
Kingston 32GB DDR4 2666MHz ECC Memory
4 | £380.96 |
Easily duplicate one USB 2.0 Flash Drive to two Flash Drives simultaneously or Erase USB Flash Drives, without connecting to a computer. The USBDUP12 Standalone Flash Drive Duplicator/Eraser offers a quick and easy solution for cloning a USB flash drive to one or two target USB flash drives or erasing up to two thumb drives simultaneously without having to connect the drives to a computer system.
Featuring high performance duplications at up to 1.5GB per minute, the flash drive copier has a lightweight design and user friendly interface that includes an integrated LCD display. The duplicator can copy the entire source drive volume, or for quicker backups just the data on the drive.
In addition, the target USB ports of the duplicator also support connecting to external USB storage devices. The standalone USB duplicator supports copying/cloning to SD/ SDHC/ Micro SD/ MMC/ Mini SD/ CF media through a USB multimedia card reader (sold separately), and to Hard Drives or Solid State Drives through a Hard Drive docking station or USB enclosure.
The Drive Duplicator also functions as a Flash Drive Eraser capable of erasing up to two USB drives simultaneously with several erase modes available including Quick erase and Full erase, as well as Secure erase, which follows the USA Department of Defense (DoD) secure erase standard, passing over the flash drive 3 times to ensure that the data has been completely wiped.
Product Description | StarTech.com 1:2 Standalone USB Duplicator and Eraser - Memory Stick Cloner - USB 2.0 Flash Drive Copier / Thumb Eraser (USBDUP12) - USB drive duplicator | Device Type | USB drive duplicator | Colour | Black | Installed Devices / Modules Qty | 2 (max) | Localisation | North America, United Kingdom, Europe | Built-in Devices | Status LCD | Hard Drive | No HDD | Power | AC 120/230 V | Dimensions (WxDxH) | 13 cm x 12 cm x 2.5 cm | Weight | 190 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: SVA5H2NEUA |
General | |
Enclosure Colour | Black |
Chassis | |
Supported Devices / Modules Qty | 2 |
Hard Drive | |
Type | No HDD |
Expansion / Connectivity | |
Interfaces | 3 x USB 2.0 - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V |
Dimensions & Weight | |
Width | 13 cm |
Depth | 12 cm |
Height | 2.5 cm |
Weight | 190 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 5 - 95% |
Compatibility Information | |
