ITEM | QTY | PRICE |
Samsung 50" QN90C Neo-QLED 4K Ul...
4 | £3,316.00 |
OtterBox Defender Samsung Galaxy Tab...
3 | £140.43 |
Samsung 43" CU7100 4K UltraHD HD...
3 | £747.00 |
The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks. Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
The shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
Product Description | StarTech.com 1.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Grey, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT150CMGR) - patch cable - 1.5 m - grey | Type | Patch cable - CAT 6a | Technology | Shielded twisted pair (STP) | Shielding Material | Aluminium-polyester foil | Wires per Cable | 8 wires | Features | Molded, snagless, RFI/EMI shielding | Length | 1.5 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Grey | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 6a |
Jacket Material | PVC |
American Wire Gauge (AWG) | 26 |
Pairs per Cable | 4 pairs |
Length | 1.5 m |
Weight | 67 g |
Colour | Grey |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
