The HDDVIMM150CM HDMI to DVI-D cable comes in a non-standard 1.5 meter/5 foot cable length allowing for a convenient connection distance and enabling you to position your DVI-D or HDMI-enabled devices as needed.
This bi-directional cable enables you to connect a DVI-D video card to a display that incorporates HDMI technology, or enables you to connect an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high-performance cable is designed to provide the best quality picture available through HDMI technology or DVI digital connections.
Product Description | StarTech.com 1.5m HDMI to DVID Cable M/M - adapter cable - HDMI / DVI - 1.5 m | Cable | Adapter cable - HDMI / DVI | Technology | Shielded | American Wire Gauge (AWG) | 28 | Length | 1.5 m | Colour | Black | Connector | DVI-D - male | Connector (Second End) | HDMI - male | Features | Moulded, strain relief | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | Adapter cable |
Interface Supported | HDMI / DVI |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 1.5 m |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 18+1 pin digital DVI (Single-Link) - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
