Create Ultra HD connections between your High Speed HDMI-equipped devices over a unique 5 foot connection distance. The HDMM150CM 1.5m High Speed HDMI cable comes in a non-standard 5 foot cable length allowing for a convenient connection distance and enabling you to position your HDMI-enabled devices as needed.
The cable features two gold-plated HDMI male connectors to provide a dependable HDMI to HDMI connection, while the unique cable length makes it perfect for watching videos from your laptop on your HDMI TV or for boardroom presentations when connecting your laptop to an HDMI-enabled projector.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
Product Description | StarTech.com 1.5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M - 5 ft HDMI 1.4 Cable - Audio/Video Gold-Plated (HDMM150CM) - HDMI cable - 1.5 m | Cable | HDMI cable | Technology | Double shielded | American Wire Gauge (AWG) | 28 | Length | 1.5 m | Colour | Black | Connector | HDMI - male | Connector (Second End) | HDMI - male | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: MSTCDP122HD |
General | |
Cable Type | HDMI cable |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 1.5 m |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 19 pin HDMI Type A - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
