StarTech.com 1 m/3.3 ft USB C to Lightning Cable - White
£14.74
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Charge your devices using an MFi certified Lightning cable built to withstand your daily routine
  • Durable Lightning cable is reinforced with Kevlar aramid fiber for increased tensile strength that is 5x stronger than steel
  • Extended strain relief tested to tolerate over 10,000+ bend cycles at 180° angle
  • Length: 1m
  • Stock Status: In Stock
Product codes
This 1 m (3 ft.) white USB C to Lightning cable withstands the daily demands of charging and syncing your iPad, iPhone or other mobile devices featuring the Lightning connector. Tested to endure strenuous wear and tear and winter and summer in-car use, the strong and rugged cable is a must-have for both business and consumer applications.
The durable USB C to Lightning cable has aramid fiber reinforcement that shelters it from the stress of frequent bends and twists. This also lets the heavy duty cable flex without over-stretching and strengthens the core of the cable.
Cable Key Features. Aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil with braided shielding. TPE (thermoplastic elastomer) cable jacket is softer and more flexible than a standard PVC cable and environmentally friendly.
The reinforced cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle. Plus, the improved inner molding resists cracking and reduces cable damage.
Connector Key Features. Lightning connector provides 12W so your charger can charge your iOS devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle.
Product Description StarTech.com 1m USB C to Lightning Cable - iPhone iPad Fast Charging Durable White Charge & Sync Cord w/Aramid Fiber Apple MFI Certified - Lightning cable - Lightning / USB 2.0 - 1 m
Cable Lightning cable - Lightning / USB 2.0
American Wire Gauge (AWG) 22/32
Length 1 m
Colour White
Connector Lightning - male
Connector (Second End) USB-C - male
Compliant Standards USB / USB 2.0
Features Sync and charge, strain relief, EMI/RFI protection, aramid fibre core
Designed For Apple 10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; 5; iPad with Retina display; iPhone 11, 5, 5c, 5s, 6, 6s, 7, 8, SE, X, XR, XS, XS Max; iPod nano; iPod touch
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 m/3.3 f...
£14.74
