StarTech.com 1 Port RS232 Serial to IP Ethernet Converter / D...
StarTech.com 1 Port RS232 Serial to IP Ethernet Converter / Device Server - Aluminum
£120.78
22 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Connect to, configure and remotely manage an RS-232 serial device over an IP network. The NETRS2321P 1 Port Serial to Ethernet Converter is an effective serial over IP solution that lets you connect to, configure and remotely manage an RS-232 serial device over a LAN. The RS-232 to Ethernet converter is designed to function seamlessly with your integrated serial ports, giving you the tools to communicate with remote RS-232 devices as if they were connected directly.
The adapter offers versatile browser-based or Virtual Com port software configuration for customizing the device to suit your application. The adapter also offers remote Telnet configuration and support for IP, HTTP, ICMP, DHCP, ARP, TCP and UDP protocols, while providing baud rates of up to 460.8Kbps.
With a sturdy aluminum enclosure and DIN-Rail or wall mountable brackets, the serial device server provides a durable remote serial interface for industrial automation, security, Point of Sale and many others.
Product Description StarTech.com 1 Port RS232 to Ethernet IP Converter / Device Server - Aluminum - Serial over IP Device Server - Serial to IP Converter (NETRS2321P) - device server
Device Type Device server
Form Factor DIN rail mountable
Localisation North America, United Kingdom, Europe
Data Link Protocol Ethernet, Fast Ethernet, RS-232
OS Required Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019
Power AC 100/230 V
Dimensions (WxDxH) 5.3 cm x 8.1 cm x 2.3 cm
Weight 295 g
Designed For P/N: SVA12M2NEUA, SVA12M5NA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 Port RS...
£120.78
