StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI
£31.26
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • USB to Null Modem (Cross-Wired) RS232 Serial Adapter
  • Integrated FTDI USB UART Chip
  • Baud Rate up to 921.6Kbps
  • COM Port assignments maintained across reboot
  • USB-powered - no external power adapter required
  • Compatible with USB 1.1 or 2.0 Ports
Product codes
chevron icon
chevron icon
Add a Null Modem RS232 serial port to your laptop or desktop computer through USB. The ICUSB232FTN FTDI USB to Null Modem Serial Adapter Cable (1 port) converts an available USB 1.1 or 2.0 port into an RS232 Null Modem serial DB9 port, solving DCE/DTE conflicts directly, without requiring additional cross-wired serial cables or adapters.
This compact adapter features COM retention, allowing the same COM port value to automatically be re-assigned to the port if the cable is disconnected and re-connected to the host computer, or if the system is rebooted. The integrated FTDI chipset supports additional customization, advanced features, and compatibility not necessarily offered by other solutions.
The USB to Null Modem adapter is compatible with a broad list of operating systems including Windows, Windows CE, Mac OS and Linux, making it easier to integrate into mixed environments.
chevron icon
Product Description StarTech.com USB to Serial RS232 Adapter - DB9 Serial DCE Adapter Cable with FTDI - Null Modem - USB 1.1 / 2.0 - Bus-Powered (ICUSB232FTN) - serial adapter - USB 2.0 - RS-232
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports RS-232
Dimensions (WxDxH) 4.2 cm x 4.5 cm x 2.2 cm
Length 1.8 m
Weight 140 g
Data Link Protocol RS-232
Data Transfer Rate 921.6 Kbps
Compliant Standards USB 1.1, USB 2.0
Colour Black
System Requirements Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£31.26
