This Ethernet to MM Fiber Media Converter creates a cost-effective Ethernet to fiber link, transparently converting to/from 10Base-T or 100Base-Tx Ethernet signals and 100Base-Fx optical signals to extend an Ethernet network connection over a multimode fiber backbone.
The converter supports a maximum multimode fiber optic cable distance of 2km (1.2 miles), providing a simple solution for connecting 10Base-T/100Base-Tx Ethernet networks to remote locations using ST-terminated multimode fiber, while delivering solid network performance and scalability.
Easy to setup and install, this compact, value-conscious media converter features auto-switching MDI and MDI-X support on the RJ45 UTP connections as well as manual controls for UTP mode, speed, Full and Half Duplex, as well as LFP (Link Fault pass-through) on/off.
Product Description | StarTech.com 10/100 Multi Mode Fiber Copper Fast Ethernet Media Converter ST 2 km - fibre media converter - 10Mb LAN, 100Mb LAN | Device Type | Fibre media converter - RJ-45 / ST multi-mode | Form Factor | External | Localisation | United Kingdom | Cabling Type | 10Base-T, 100Base-FX, 100Base-TX | Data Transfer Rate | 100 Mbps | Optical Wave Length | 1310 nm | Data Link Protocol | 10Mb LAN, 100Mb LAN | Max Transfer Distance | 2 km | Dimensions (WxDxH) | 7.3 cm x 9.7 cm x 2.3 cm | Weight | 90 g | Manufacturer Warranty | 1-year warranty |
General | |
Device Type | Fibre media converter |
Networking | |
Connectivity Technology | Wired |
Status Indicators | Port duplex mode, power, link/activity |
Features | Flow control, auto-negotiation, half duplex mode, full duplex mode |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x Ethernet 100Base-FX - ST multi-mode female x 2 |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | External power adapter |
Dimensions & Weight | |
Width | 7.3 cm |
Depth | 9.7 cm |
Height | 2.3 cm |
Weight | 90 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 90% |
