StarTech.com 100ft. Hook and Loop Roll - Blue - Reusable
£25.64
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Hassle-free cable management with hook-and-loop fastening fabric
  • Conveniently cuts to your desired length
  • Versatile binding solution with a strong, heavy duty hold
  • Stock Status: In Stock
Product codes
This 100 ft. roll of hook and loop roll tape makes it easy to keep your cables neat and tidy by binding them together or binding them to a structure.
This roll of hook and loop fastener straps offers a quick and easy solution for bundling cables together and securing your cables for better routing. Help protect your equipment by reducing cable tension and preventing excessive heat caused by unorganized cables restricting airflow.
You can cut the roll of hook and loop fastener fabric to size using household scissors, meaning you can choose the perfect length for your specific application.
While the most common use for this hook-and-loop fabric is binding and routing cables, you can also use it for other materials in your IT environment such as tools or raceways. The reusable tie wraps are easy to remove and adjustable, avoiding the hassle and waste of traditional zip ties.
Product Description StarTech.com 100ft. Hook and Loop Roll - Blue - Cable Management - hook & loop fastener
Product Type Hook & loop fastener
Dimensions (WxDxH) 1.9 cm 0.238 cm
Length 30.48 m
Weight 500.775 g
Colour Blue
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 100ft. Ho...
£25.64
