ITEM | QTY | PRICE |
Kingston 8GB DDR4 2666MHz Module Memory
4 | £80.24 |
Lenovo ThinkPad USB 3.0 Secure HDD-500GB
3 | £515.19 |
Crucial 16GB DDR4 3200 MHz DIMM CL22...
4 | £136.20 |
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 10m - Turquoise - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
Product Description | StarTech.com 10m CAT6a Ethernet Cable - Aqua - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 10 m - aqua | Type | Patch cable - CAT 6a - IEEE 802.3bt | Technology | S/FTP | Shielding Material | Foil | Wires per Cable | 8 wires | Features | Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps | Length | 10 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Aqua | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 6a - IEEE 802.3bt |
Jacket Material | Low Smoke Zero Halogen (LSZH) |
American Wire Gauge (AWG) | 27 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 10 m |
Weight | 340.3 g |
Colour | Aqua |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz |
Dimensions & Weight (Shipping) | |
Shipping Width | 31 cm |
Shipping Depth | 22 cm |
Shipping Height | 4.5 cm |
Shipping Weight | 357.4 g |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
