ITEM | QTY | PRICE |
HP Color LaserJet Pro MFP 4302dw
4 | £1,627.36 |
Apple Watch Charge cable USB-A
4 | £119.40 |
C2G 3m Velocity™ TOSLINK® Optica...
2 | £35.72 |
We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 10m - Turquoise - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
Product Description | StarTech.com 10m CAT6a Ethernet Cable - Aqua - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 10 m - aqua | Type | Patch cable - CAT 6a - IEEE 802.3bt | Technology | S/FTP | Shielding Material | Foil | Wires per Cable | 8 wires | Features | Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps | Length | 10 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Aqua | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 6a - IEEE 802.3bt |
Jacket Material | Low Smoke Zero Halogen (LSZH) |
American Wire Gauge (AWG) | 27 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 10 m |
Weight | 340.3 g |
Colour | Aqua |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz |
Dimensions & Weight (Shipping) | |
Shipping Width | 31 cm |
Shipping Depth | 22 cm |
Shipping Height | 4.5 cm |
Shipping Weight | 357.4 g |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
