Make Fast Ethernet connections with support for PoE. This Cat5e patch cable delivers reliable network connections, which ensures high-performance capability for your demanding Ethernet applications.
This 10-meter yellow network cable is perfect for use in network conduits and raceways. The cable is intended for longer distance applications, such as running up a post or throughout the office from a hub to a wall- jack.
For easier network installations, the Cat 5e cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The cable also features molded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
Get the highest value for your cable investment with the Cat5e Ethernet cables, each one manufactured using high-quality copper conductors. They are carefully constructed and tested, to keep Near-End Crosstalk (NEXT) well within acceptable limits.
Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet and 4K or 1080p video streaming, using cables that include 24 AWG copper.
You can rely on the RJ45 connectors to deliver optimum conductivity, while eliminating signal loss due to oxidation or corrosion.
Product Description | StarTech.com 10m Yellow Cat5e / Cat 5 Snagless Ethernet Patch Cable 10 m - patch cable - 10 m - yellow | Type | Patch cable - CAT 5e | Technology | Unshielded twisted pair (UTP) | Wires per Cable | 8 wires | Features | Snagless, stranded | Length | 10 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Yellow | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 5e |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 10 m |
Weight | 325 g |
Colour | Yellow |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS, WEEE - up to 350 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
