StarTech.com 12in 15 pin SATA Power Extension Cable
£9.76
40 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by a StarTech.com lifetime warranty
  • Eliminates the need to bend or strain the SATA cable to account for a lack of space
  • Extends the reach from the SATA power connection to your SATA drive by up to 12", providing more flexibility
  • Length: 30.5cm, <1m
Product codes
chevron icon
chevron icon
Extend a SATA Power Connection by up to 12in. The SATAPOWEXT12 SATA Power Extension Cable (15-pin, 12-inch) enables you to extend the reach between internal SATA power and drive connections by up to 12 inches.
The extension cable helps to simplify drive installation by overcoming typical connection limitations and reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary connection.
chevron icon
Product Description StarTech.com 12in 15 pin SATA Power Extension Cable - SATA Power Male to Female Extender - 12 Inch SATA Power Extension Cord - power extension cable - SATA power to SATA power - 30.5 cm
Type Power extension cable
Length 30.5 cm
Connector 15 pin Serial ATA power - male
Connector (Second End) 15 pin Serial ATA power - female
Manufacturer Warranty 1-year warranty
Designed For P/N: PYO2SATA, PYO4SATA, SATAPOWADAP
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£9.76
